Page 13 of 19
Re: RuneAudio+R e4
PostPosted: 27 Jul 2020, 20:52
by R101
klassikmann wrote:
RolandBlaze wrote:
R101 wrote:@rern,
The latest update is working well for me, but the problem of having to choose whether to have the volume control or the cover art on the playback page is still there. If I disable the cover art, the disabled volume control appears.
yup have this also.
@R101 @RolandBlaze
To assist rern in identifying the problem, please post your playback settings.
Here a mine (both volume control and coverart are present (plus time):
Checked are: "Time", "WebRadio elapsed", "Cover art", "Volume"
klassikmann
My playback settings:
MPD settings have no volume enabled and mixer disabled.
Re: RuneAudio+R e4
PostPosted: 28 Jul 2020, 13:51
by rern
R101 wrote:...
Please tell what would be the layout you try to set.
Re: RuneAudio+R e4
PostPosted: 28 Jul 2020, 17:12
by Sn4kY
Hi.
i've just download and install a fresh copy of RA+Re4
When I switch on the UPnP feature, it fallback to off.
there are some details :
● upmpdcli.service - UPnP Renderer front-end to MPD
     Loaded: loaded (/usr/lib/systemd/system/upmpdcli.service; enabled; vendor preset: disabled)
    Drop-In: /etc/systemd/system/upmpdcli.service.d
             └─override.conf
     Active: activating (auto-restart) (Result: exit-code) since Tue 2020-07-28 18:00:43 CEST; 25s ago
    Process: 3159 ExecStart=/usr/bin/upmpdcli -c /etc/upmpdcli.conf (code=exited, status=127)
   Main PID: 3159 (code=exited, status=127)
If I try to exec in SSH :
root@runeaudio+R e4:~ # /usr/bin/upmpdcli -c /etc/upmpdcli.conf
/usr/bin/upmpdcli: error while loading shared libraries: libjsoncpp.so.22: cannot open shared object file: No such file or directory
I have installed jsoncpp but without no changes
I think the upmpdcli don't search the good lib :
root@runeaudio+R e4:~ # ldd /usr/bin/upmpdcli | grep json
        libjsoncpp.so.22 => not found
ls -alh /usr/lib/libjsoncpp.so*
lrwxrwxrwx 1 root root   16 Jul 19 21:22 /usr/lib/libjsoncpp.so -> libjsoncpp.so.24
-rwxr-xr-x 1 root root 178K Jul 19 21:22 /usr/lib/libjsoncpp.so.24
Okay, well, trying to symlink...
cd /usr/lib/
ln -s libjsoncpp.so libjsoncpp.so.22
and restarting...
Good job !
             └─override.conf
     Active: active (running) since Tue 2020-07-28 18:10:37 CEST; 52s ago
   Main PID: 5287 (upmpdcli)
      Tasks: 10 (limit: 2140)
     CGroup: /system.slice/upmpdcli.service
             └─5287 /usr/bin/upmpdcli -c /etc/upmpdcli.conf
Maybe other people will have this bug ?
Re: RuneAudio+R e4
PostPosted: 28 Jul 2020, 17:39
by klassikmann
Update Re4 20200728
The problem with thumnails in the coverart view is still present.
klassikmann
klassikmann wrote:
klassikmann wrote:Update Re4 20200726
The thumbnails in the coverart library view are missing. The entries are present and it's also possible to click on an invisible coverart to select an album.
Edit: After some clicking back and forth the thumbnails are back again.
Edit 2: Some clicks later the thumbnails are gone again, ..., and come back again.
klassikmann
An Observation:
If the thumbnails are invisible in the coverart view, I select an album as a new playlist and the thumbnails are back again. Clearing the playlist and refreshing the browser window (F5) and the thumbnails vanish. Tested with Firefox and Chrome.
klassikmann
Re: RuneAudio+R e4
PostPosted: 28 Jul 2020, 17:41
by R101
rern wrote:
R101 wrote:...
As in the screenshot above, rern. If I untick the cover art, the volume control appears. The volume option is greyed out and cannot be changed. Volume is turned off in the bit-perfect setting.
Re: RuneAudio+R e4
PostPosted: 29 Jul 2020, 17:49
by AndyF
klassikmann wrote:Update Re4 20200728
klassikmann
klassikmann
An Observation:
klassikmann
Hi klassikmann,
on my system, coverart-view works fine on every browser. Maybe there's a "problem"-thumbnail in your folder?
I would try to temporarly move them in a different folder and move them back step-by-step until error occurs.
regards, Andy
Re: RuneAudio+R e4
PostPosted: 29 Jul 2020, 18:42
by klassikmann
Hallo Andy,
thank you for your information about the non-existence of the problem in your environment. I'm doubtful whether the problem is specific to my installation or a general one. I have about 2000 coverarts so that it is rather time consuming following your proposal ("I would try to temporarly move them in a different folder and move them back step-by-step until error occurs."). What I just did is to restore an old backup and the problem persists.
Hm?
klassikmann
Re: RuneAudio+R e4
PostPosted: 29 Jul 2020, 19:22
by AndyF
Hallo klassikmann,
maybe it's possible to copy them in alphabetical steps? I've got only 350 thumbnails with following access rignts:
-rw-r--r-- http:http
Only .jpg's are inside. But I don't have much songs with special characters in its name ...
regards, Andy
Re: RuneAudio+R e4
PostPosted: 29 Jul 2020, 19:27
by klassikmann
Hi Andy,
tomorrow I'll try to bring more light into the dark.
klassikmann
Re: RuneAudio+R e4
PostPosted: 29 Jul 2020, 19:37
by AndyF
Hallo klassikmann,
WinSCP is an explorer-like tool with SSH-access - it's worth a try for such copy-actions.
Regards, Andy
