Hi All,
I am not able to configure properly RuneAudio to stream tidal from BubbleUPnP. I am using the RuneAudio+R e6 release..In that release there is only UPnP button to switch on/off, no credential to add a in the previus release.
The message I get is the following:
- Code: Select all
● upmpdcli.service - UPnP Renderer front-end to MPD
Loaded: loaded (/usr/lib/systemd/system/upmpdcli.service; enabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/upmpdcli.service.d
└─override.conf
Active: activating (auto-restart) (Result: exit-code) since Sat 2021-11-06 14:44:21 CET; 37s ago
Process: 14882 ExecStart=/usr/bin/taskset -c 3 /usr/bin/upmpdcli -c /etc/upmpdcli.conf (code=exited, status=1/FAILURE)
Main PID: 14882 (code=exited, status=1/FAILURE)
CPU: 34ms
BubbleUPnP detect the raspberry, but fail to read a song when I choose the library from Tidal and it seems it requires some credential.....
I tried to configure /etc/upmpdcli.conf myself with the help of some advice I found here and there...but my skills are unfortunately a bit limited.
If anyone has already setup tidal to run with BubbleUpnP + rune, I am in interested in knowing the way
THank you
