Hi Rern
Report back after further testing :
unfortunately on my system the image isn't really working well
I can't seem to add my 8k+ music database, settings aren't retained, even after succesfull logon to nfs server dir
A faulty one was added (my CD collection resides in the very original named 'Music' folder), when adding this a folder 'Music\ ' was added, yet cannot be removed
I can't re-add the same server again either
searching where these NAS login data are saved manually yields no results so far
- Code: Select all
grep -rnw '/' -e "/Music\ "
and variants
adding the server under a different name works though so remove function seems to have a bug
also : you state it's better to use an usb stick for saving settings, yet no files are saved there it would appear
Playing webradio works for some time, but there are sometimes some quite long lag times (Wifi N, pretty crowded, slow ISP) and the option to set the buffer size that exists in the original 0.5 b or earlier version is not available though gui
So the system plays, but drops after a while to become locked and unresponsive on the gui, ssh still worked, but issuing a reboot command results in a blocked SD card. Another repair session on linux station and I can boot again.
It appears that it is very much hit or miss to try and do a warm/cold reboot on this version. Pretty easy to corrupt SD card
Auto play option doesn't start if you manage to reboot the system
I can install my pydPiper scripts to use my LCD screen, yet the connection to the MPD daemon has changed from janui's 0.5b version, so nothing is displayed when streaming music
A good note (Me thinks) :
on the MPD settings page, you have to hit the cog wheel and set the Volume Level Control to 'none' to preserve the No Volume switch
Sorry for the bad news, still hoping to get a stable version soon that can use all of my hardware and runs rock solid
D
RPI 2, Sabre DAC/AMP, audiophonics ATX, hd44780 LCD
