Page 3 of 5
Re: Rune UI is slow
Posted:
31 May 2019, 10:37
by Golgi
Yes, works like a charm.
Thanks RandomRuneUser, good job!
Golgi
Re: Rune UI is slow
Posted:
31 May 2019, 11:31
by englishtim
Hi Everyone,
Works here too - thanks to RandomRuneUser for the fix!
Please note that - unsurprisingly - Dirble no longer works when the fix is applied. I don't use it here, but those of us who do use it should just be aware...
Peace and friendship,
englishtim
Re: Rune UI is slow
Posted:
31 May 2019, 15:21
by dragos_nedelcu
Works perfectly!!!!!! Thank you!!!!!
Re: Rune UI is slow
Posted:
31 May 2019, 15:31
by dragos_nedelcu
Faster than first install. Thank you RandomRuneUser!!!!!!!!!
Re: Rune UI is slow
Posted:
31 May 2019, 20:12
by Ears of Tin
Here's another thank you for the fix. Working great and I got to use SSH for the first time.
Re: Rune UI is slow
Posted:
31 May 2019, 20:21
by Colin
This is due to the Dirble
http://api.dirble.com/ not responding anymore.
I've not found a way to disable it yet, will look into it.
Edit: I've made a merge request that adds a setting to disable it :
https://github.com/gearhead/RuneUI/pull/18
Re: Rune UI is slow
Posted:
01 Jun 2019, 10:51
by Tantal
The interface works as usual again,
without editing any files.
Re: Rune UI is slow
Posted:
01 Jun 2019, 10:57
by tml3nr
RandomRuneUser wrote:dynobot wrote:Would something like iftop or some other network monitoring tool be of use to determine what is trying to connect to what and holding up the UI?
using iftop I can see lastfm-api-vip1.phx1.cbsig.net as possibly being the problem....any way to remove this from Rune?
I ran a trace on my router and saw timeouts with my pi connecting to api.dirble.com that corresponded closely to the delays in the UI. Just blocking that IP did not work, but wildcard-blacklisting dirble.com on my pi-hole did.
(^|\.)dirble\.com$
If you don't have control over your DNS, probably you could edit the hosts file on your rune box (or whatever the equivalent is ... I'm not super familiar with arch linux.)
Edit: can confirm that adding the following to /etc/hosts works:
127.0.0.1 api.dirble.com dirble.com
It works perfectly! Many thanks RandomRuneUser.
Re: Rune UI is slow
Posted:
02 Jun 2019, 16:14
by Toube
Works like a charm, great work @RandomRuneUser thanks.
-Toube
Re: Rune UI is slow
Posted:
05 Jun 2019, 08:41
by anana
This resolved the issue. (Added wildcarded dirble.com to my pihole blacklist.)
It may work now even faster than before. Thank you!
