Pi Supply Switch
Posted: 15 Sep 2018, 14:13
Has anyone got the Pi Supply Switch working.
My setup is Pi 3B running on 0.4 beta version of runaudio with Hifiberry Digi Dac B+ HW 1.1
I used the https://github.com/PiSupply/Pi-Supply-Switch but this gives me whiptail: command not found error.
The connectors are on the recommended pins 7 & 11 the system will boot when pin 7 is connected to a ground but otherwise it just hangs.
As far as I can there should be no conflict with the DAC using these pins.
Any assistance/guidance would be appreciated.
