Page 61 of 63
PostPosted: 28 Jan 2020, 22:11
by McFly
Removed the digi and HDD, same error...
Just to be sure : I burned the image on a 32g SD card and tried to boot with it, wich gave me the error message. This is the right way to do, yes?
I know jack shit about what these error codes means. HELP!!!
PostPosted: 04 Feb 2020, 01:24
by ayase1121
Hello. In runeaudio 0.5 Release version: 0.5 (build: janui-20180903), the so-called screensaver screen (the large album art is displayed on the left and the artist information is displayed on the right) no longer displays the artist's photos in an unforeseen time. Was. The part where the photo was displayed has a very light gray and white star display. Is it possible to improve this and display photos with Artis as before?
PostPosted: 06 Feb 2020, 01:01
by CrivenS
Greetings,
I'm having problems haven't managed to successfully boot yet, and I have tried both available images on two different SD cards (a 64 and a 32) using usb image tool:
RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB
RuneAudio_ODROIDC2_0.4-beta_20160518_2GB
I've never yet seen even a flicker of green from the pi to indicate SD reading. and only had the rainbow screen on hdmi.
I have successfully had M2P, Moode and Volumio run from each card as well to test.
Kind of at my wits end. Any suggestions would be appreciated.
PostPosted: 06 Feb 2020, 02:42
by rastus
CrivenS wrote:...and only had the rainbow screen on hdmi.
The rainbow screen is the Raspberry Pie's way of saying, "I need more power please."
PostPosted: 06 Feb 2020, 03:34
by CrivenS
rastus wrote: The rainbow screen is the Raspberry Pie's way of saying, "I need more power please."
Ok...!?
but that doesn't really help very much. I have two power adapters, both work. The Pi clearly works fine with other images. I've tried both of the available Rune Pi 3+ images. What other trouble shooting should I try? Older Pi images?
PostPosted: 06 Feb 2020, 20:28
by EZJstef
hi all,
i am wonder if special script needed on rune 0.5 to use power on button with the audiophonics pcb
https://www.audiophonics.fr/fr/kits-et-modules-diy/audiophonics-pi-spc-v2-module-de-controle-alimentation-type-atx-pre-assemble-p-11125.html
because seems not working in good condition .... without any change on runeaudio image
anyone can help me?
regards Stef
PostPosted: 07 Feb 2020, 12:40
by CrivenS
If anyone can suggest another image or boot condition worth investigating I'll give it a shot but otherwise, well, I'm about ready to call it quits with Rune.
I have a pair of Pi 3 B+'s, three SD cards, and I have tried a great variety of boot conditions; with and without network, USB peripherals, audio and HDMI connections. Ive tried both the 0.4-beta_20160518 and 0.4-beta_20160321images with both recommended Windows SD image mounting programs.
I've tried adding boot delays to the config txt as recommended here:
https://raspberrypi.stackexchange.com/q ... bow-screen
I have never yet seen a green led light up at all for a Rune image. The older image doesn't even make it to the rainbow.
For comparison both Pi and all three SD cards have been tested to successfully launch and run Moode, M2P and Volumino Images first time every time.
PostPosted: 11 Feb 2020, 21:46
by Cyborg_delta1
McFly wrote:Removed the digi and HDD, same error...
I just noticed on mine I get the same message when the local browser is disabled, try accessing it from another computer on the network and it should be fine.
PostPosted: 11 Feb 2020, 22:15
by Cyborg_delta1
CrivenS wrote:Greetings,
Hi Criven
Well odroidc2 wont work as that is a different SBC also the images you mentioned are not 0.5 as 0.5 is an unofficial update to rune audio. If you want to use 0.5 for your 3b+ you need to get it from here:
http://www.mediafire.com/file/16d92z7jb ... mg.gz/file
If you go to page 1 of this thread it will give you all the information from the creator.
I would recommend using Win32DiskImager as I have never had an issue when writing to SD cards because the errors you are describing you don't get past the rainbow screen and nothing from the activity LED sounds like the image was not written to the SD card correctly:
Win32DiskImager
-Insert the SD card into your SD card reader. You can use the SD card slot if you have one, or an SD adapter in a USB port. Note the drive letter assigned to the SD card. You can see the drive letter in the left hand column of Windows Explorer, for example G:
-Download the Win32DiskImager utility from the Sourceforge Project page as an installer file, and run it to install the software.
-Run the Win32DiskImager utility from your desktop or menu.
-Select the image file you extracted earlier.
-In the device box, select the drive letter of the SD card. Be careful to select the correct drive: if you choose the wrong drive you could destroy the data on your computer's hard disk! If you are using an SD card slot in your computer, and can't see the drive in the Win32DiskImager window, try using an external SD adapter.
-Click 'Write' and wait for the write to complete.
-Exit the imager and eject the SD card.
PostPosted: 11 Feb 2020, 22:53
by Cyborg_delta1
EZJstef wrote:hi all,
anyone can help me?
regards Stef
Hello yes it will need a script as it sates on the website and gives you the instructions there
http://forum.audiophonics.fr/viewtopic. ... 6a16961c81
scroll down and it will have runeaudio 0.4 instructions but you will have to SSH into the pi to do it
