Posted: 29 Jul 2019, 13:57
Hi TFZ02,
No, not yet.TFZ02 wrote:already exists a version for the Pi4+?
Embedded hi-fi music player
https://www.runeaudio.com/forum/
https://www.runeaudio.com/forum/runeaudio-0-5-beta-for-all-raspberry-pi-models-t6532-550.html
Yes, thanks, I know about this. It's on my list of things to do.HJLK wrote:...the volume UP/DOWN buttons start to work only AFTER I adjust the volume once thru the wheel...
I am not sure it will help with your problem, but you can add a "metadata_to_use" clause in /etc/mpd.conf by logging in via SSH and using this command:HJLK wrote:...This may be helped by adding a "metadata_to_use" line (with tags to use) in mpd.conf BUT I cannot change the mpd.conf file...
redis-cli hset mpdconf metadata_to_use "tags"
redis-cli hdel mpdconf metadata_to_use
That’s pretty much what I expected.HJLK wrote:...The results are not promising: whenever I have an mp3-album with "artist" and "albumartist" both filled...
Yes, this is normal, see here: runeaudio-0-5-beta-for-all-raspberry-pi-models-t6532-360.html#p27201mickburke wrote:...driver 'sdhost-bcm2835' is already registered, aborting...
...Any idea what's going on?...
janui wrote:Hi HJLK,That’s pretty much what I expected.HJLK wrote:...The results are not promising: whenever I have an mp3-album with "artist" and "albumartist" both filled...
You could look at this post: add-more-categories-to-music-library-t3020.html#p10618
and this one: using-album-artist-t3782.html#p16170e
This one as well: album-artist-implementation-t4012.html#p17424
