Hi AudioRotor,
AudioRotor wrote:Recently I've noticed that NAS is not going to sleep mode as usually when not used, but starts up again and again, even if not used. Issue stopped once I shut down Rune.
Please upgrade to the latest patch version of RuneAudio, there are instructions in the first post in this thread. Then retest. If you still have problems. Make sure Rune is not playing and retest. Try this from SSH:
- Code: Select all
cat /proc/asound/card?/pcm?p/sub?/hw_params | grep -v closed
You will get no output if rune is stopped.
If that doesn’t work log via SSH and rename the file /usr/bin/smartctl like this:
- Code: Select all
mv /usr/bin/smartctl /usr/bin/smartctl_save
And retest. If this works please report back. Otherwise rename the file back to its original name with this:
- Code: Select all
mv /usr/bin/smartctl_save /usr/bin/smartctl
AudioRotor wrote:Looking into mapping details I saw that parameter was changed to vers=2.0 automatically and I cannot change it back to 1.0, maybe that's the issue. I know WD I am using is pretty old so maybe its not really important issue, letting you know in case its also an issue for other devices.
It should make no difference, you should get better performance, reliability and security with the higher version. But you can revert to using vers=1.0 by modifying the 'Mount Flags' in 'Advanced options' in 'NAS Mounts' in the 'Sources UI'. This should work:
- Code: Select all
cache=none,ro,vers=1.0
