Page 2 of 5
Re: Spotify Connect on RuneAudio
PostPosted: 27 May 2018, 08:45
by kaczor189
I don't know how :/
PostPosted: 27 May 2018, 13:02
by grofweg
See this post. That might be the easiest way to expand your SD:
viewtopic.php?p=25217#p25217
PostPosted: 27 May 2018, 22:58
by rastus
kaczor189 wrote:I don't know how :/
This is the only version of expanding the partition on Runeaudio that I've found that actually works!
https://archlinuxarm.org/forum/viewtopi ... 119#p18160
Helpful.
PostPosted: 04 Jun 2018, 20:50
by kaczor189
I managed to extend partition, thank you.
I have next problem. I did everyhing step by step, using WinSCP I copied spotify_appkey.key to /root/spotify-connect-web-chroot/usr/src/app, overwrited console_callbacks.py using text given here https://github.com/JozoVilcek/spotify-connect-web/blob/855b92b49555cdcc11d0ab4c71866475cd7c9499/console_callbacks.py and when I run test typing my username and password to Spotify I have problem like in the picture. I have also tried to copy all the files (spotify_appkey.key + Spotify Fix) like here http://powerpi.de/spotify-connect-auf-dem-raspberry-pi-2-installieren-dein-smartphone-ist-die-fernbedienung/ but there was also an error. Do you have any idea ?
Image https://zapodaj.net/0a3793675af07.png.html
PostPosted: 05 Jun 2018, 04:26
by tml3nr
kaczor189 wrote:I managed to extend partition, thank you.
Do not update Spotify Fix. It's not working.
Please check: --device <value> --mixer <value> from your alsamixer:
PS: If you clean install Spotify Connect Web Fornoth v003 or v004. The command line must be:
./spotify-connect-web.sh --playback_device sysdefault:CARD=BossDAC --mixer_device_index 0 --mixer Digital --username abc --password xyz --name RuneAudio --bitrate 320
More info v003 & v004:
## Usage
usage: main.py [-h] [--device DEVICE | --playback_device PLAYBACK_DEVICE]
               [--mixer_device_index MIXER_DEVICE_INDEX] [--mixer MIXER]
               [--dbrange DBRANGE] [--cors CORS] [--debug] [--key KEY]
               [--username USERNAME] [--password PASSWORD] [--name NAME]
               [--bitrate {90,160,320}] [--credentials CREDENTIALS]
Web interface for Spotify Connect
optional arguments:
  -h, --help            show this help message and exit
  --device DEVICE, -D DEVICE
                        alsa output device (deprecated, use --playback_device)
  --playback_device PLAYBACK_DEVICE, -o PLAYBACK_DEVICE
                        alsa output device (get name from aplay -L)
                        alsa card index of the mixer device
  --mixer MIXER, -m MIXER
                        alsa mixer name for volume control
  --dbrange DBRANGE, -r DBRANGE
                        alsa mixer volume range in Db
  --lastfm_username LASTFM_USERNAME
                        your Last.fm username
  --lastfm_password LASTFM_PASSWORD
                        your Last.fm password
  --lastfm_api_key LASTFM_API_KEY
                        your Last.fm API key
  --lastfm_api_secret LASTFM_API_SECRET
                        your Last.fm API secret
  --lastfm_credentials LASTFM_CREDENTIALS
                        file to load Last.fm credentials from
  --cors CORS           enable CORS support for this host (for the web api).
                        Must be in the format <protocol>://<hostname>:<port>.
                        Port can be excluded if its 80 (http) or 443 (https).
                        Can be specified multiple times
  --debug, -d           enable libspotify_embedded/flask debug output
  --key KEY, -k KEY     path to spotify_appkey.key (can be obtained from
                        https://developer.spotify.com/my-account/keys )
  --username USERNAME, -u USERNAME
                        your spotify username
  --password PASSWORD, -p PASSWORD
                        your spotify password
  --name NAME, -n NAME  name that shows up in the spotify client
  --bitrate {90,160,320}, -b {90,160,320}
                        Sets bitrate of audio stream (may not actually work)
  --credentials CREDENTIALS, -c CREDENTIALS
                        File to load and save credentials from/to
PostPosted: 06 Jun 2018, 16:30
by kaczor189
hmm… my window looks different
If it matters I have rpi3 with the latest runeuadio version.
PostPosted: 13 Jun 2018, 21:14
by Holladiewaldfee
Hi@all
is it possible to build a new RuneAudio Version > v0.3(xx)-beta?.. with a new Spotify.Lib ?
Or a Link to an anhanced SD Build with this Stuff above? - i have tried it 2 days without an
positive result :-(
Not all RuneAudio User are Linux Cracks
regards
HdWf
PostPosted: 25 Jun 2018, 13:44
by schnelle.com
I have it running on ran Rpi zero w. Everything works fine except the volume control. I use a generic USB audio card and alsamixer shows the volume control as 'Speaker'. But when I put that in as Mixer it does not work. Please help.
P.S.: it is working when I remove the mixer part in the spotify-connect.service
PostPosted: 16 Jul 2018, 04:52
by alecs123
hello.... I've been trying to setup spotify connect...
I've been able to do it without a problem on a 2nd rspb3 with a hifiberry dac+ pro, but in this new unit, I have an external USB DAC, that is recognized as "xCORE USB Audio 2.0" as the mixer and the device is 0
The problem I think is that when you have spaces in the mixer name it doesn't work
Do you know how I should be donfiguring it?
By the way, it's a SMSL M8 dac via USB
PostPosted: 16 Jul 2018, 05:34
by tml3nr
alecs123 wrote:hello.... I've been trying to setup spotify connect...
You try SC Fornoth v003. It's support all of parameter below:
ie:
./spotify-connect-web.sh --name RuneAudio --device 0 --username abc --password xyz --bitrate 320
./spotify-connect-web.sh --name RuneAudio --playback_device 'sysdefault:CARD=BossDAC' --mixer_device_index 0 --mixer Digital --username abc  --password xyz --bitrate 320
./spotify-connect-web.sh --name RuneAudio --playback_device hw:0,0 --mixer_device_index 0 --mixer Digital --username abc  --password xyz --bitrate 320
Parameter work around from:
aplay -l
aplay -L
amixer
