Page 16 of 28
Re: [Addon] Addons Menu - Install addons the easy way
Posted:
01 Aug 2018, 04:27
by rern
Herbert and @xmute,
Try:
Clear client-side cache-
Clear Browser Cache again by follow this
instructionClear server-side cache- Clear/disable OPcache - append
/dev to address bar > PHP 5.5 OPcache = Off > [ Save Settings ]
Posted:
01 Aug 2018, 06:18
by klassikmann
Hello rern,
rern wrote:Try:
First try was disappointing, no change. Next I plan to re-install Rune from scratch again, but I'm "on-the-road" until Friday.
Herbert
Posted:
01 Aug 2018, 10:01
by xmute
Hi rern
I followed your instuctions for server, client side cache cleaning and with 3 different browsers, firefox, chrome and newly installed vivaldi, on win 10 and linux, but with no luck.
Posted:
03 Aug 2018, 19:21
by clriis
It seems I got same kind of problem as Herbert and @xmute. I've tried with Firefox, Opera and Chrome (clean cache) and get the same result.
I managed to reset the addon menu using the script you supplied and that brought back the native UI, but the different items in the addon menu remains inactive meaning I can no longer install Lyrics and RuneUI etc..
When trying the /dev option I'm told it's a bad request (note attachment).
Otherwise thanks for your hard work!
Posted:
04 Aug 2018, 01:14
by rern
@klassikmann, @xmute, @clriis,
Do this for me:
- on Playback page
- swipe left/right => page changed?
- long-press => show/hide menu?
- via SSH command line
- Code: Select all
grep script /srv/http/app/templates/footer.php
ls /srv/http/assets/js/vendor
Posted:
04 Aug 2018, 01:34
by clriis
Regarding the first two questions: I assume you refer to behaviour of the Android app, but as I no longer got RuneUI installed it's back to default. As far as I remember prior to running the default script I got the menu on long press but swipe did not work.
Below is the result of requested commands
Posted:
04 Aug 2018, 02:01
by rern
@clriis,
The swipe and long-press can be used on any mobile or desktop browsers.
The scripts and the files are there.
The installation of Addons cleared OPcache by itself. But try clear/disabled OPcache again. The URL in your address bar should be:
192.168.1.62/dev
(without /addons.php)
Posted:
04 Aug 2018, 02:37
by clriis
I cleared and disabled OPCache
I restarted the Pi
I cleared all cache in a Chrome browser
When I go to Addon menu the MPD and Chrome updates are checked
When trying to install RuneUI Enhancents or Lyrics I get the dialogue box but nothing happens when I press OK other than the box diappears .
Posted:
04 Aug 2018, 02:43
by clriis
Addons
Posted:
04 Aug 2018, 02:47
by clriis
I'm running Runaudio on Pi 3 with an ALLO BOSS DAC
