Page 46 of 53
PostPosted: 06 Mar 2018, 16:23
by Ripa
the audio output is I-Sabre DAC i2s
PostPosted: 06 Mar 2018, 17:07
by janui
Hi Ripa,
This should be OK. I think you need to test it with specific files which you know will play correctly.
Try any MP3's which you have. Try a couple of flak files as well. Or see here: audiophile-test-tracks-f19.html
Try here for a 3 test files (DSD@1x28, wav@24x192k & wav@16x44k): https://positive-feedback.com/Issue64/hfs1.htm (it is important to test a 24x192k file)
When playing each test track you can see the way in which it is being processed by using the following command after logging on via SSH:
cat /proc/asound/card?/pcm?p/sub?/hw_params | grep -v closed
The command only works when something is actually playing. Make a note of the formats which are giving problems. If nothing works I suspect that your sound card is defect. If some work then your MPD settings can be adjusted, but I need to know which formats give problems.
PostPosted: 09 Mar 2018, 09:26
by Ripa
aif
access: RW_INTERLEAVED
format: S16_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 4096
buffer_size: 16384
format: S16_LE
subformat: STD
channels: 2
period_size: 4410
buffer_size: 22050
flac
format: S16_LE
subformat: STD
channels: 2
period_size: 4410
buffer_size: 22050
PostPosted: 09 Mar 2018, 09:49
by Ripa
i use DBpoweramp for ripping in the different format is this OK?
PostPosted: 09 Mar 2018, 14:39
by janui
Hi Ripa,
Ripa wrote:i use DBpoweramp for ripping in the different format is this OK?
Should be OK.
Ripa wrote:aif
format: S16_LE
The problem is that all are playing at 16bit resolution (S16_LE). The Sabre DAC’s cannot process this, but it’s easy to fix. What I do not understand is why the RPI DAC setting is not forcing output to 32bit, this worked in the past. For background information about the solution see here: i2s-port-dac-sabre-mk2-es-9018-help-t3241-30.html#p17804 and best instructions to fix it here: post18251.html?hilit=redis_acards_details%20es9018#p18251
If you change two lines in the file, you can try out the both the "HiFiBerry DAC" and the "RPI DAC" to decide which configuration sounds best for you. So edit /srv/http/db/redis_acards_details
nano /srv/http/db/redis_acards_details
change this:
    $redis->hSet('acards_details', 'snd_rpi_hifiberry_dac', '{"sysname":"snd_rpi_hifiberry_dac","extlabel":"HiFiBerry DAC (I²S)","hwplatformid":"01","type":"i2s"}');
to this:
    $redis->hSet('acards_details', 'snd_rpi_hifiberry_dac', '{"sysname":"snd_rpi_hifiberry_dac","extlabel":"HiFiBerry DAC (I²S)","card_option":"format\t\"*:24:*\"","hwplatformid":"01","type":"i2s"}');
and this:
    $redis->hSet('acards_details', 'snd_rpi_rpi_dac', '{"sysname":"snd_rpi_rpi_dac","extlabel":"I-Sabre DAC (I²S)","hwplatformid":"08","type":"i2s"}');
to this:
    $redis->hSet('acards_details', 'snd_rpi_rpi_dac', '{"sysname":"snd_rpi_rpi_dac","extlabel":"I-Sabre DAC (I²S)","card_option":"format\t\"*:24:*\"","hwplatformid":"08","type":"i2s"}');
Finish off with:
redis-cli del acards
php /srv/http/db/redis_acards_details
And reboot.
PostPosted: 10 Mar 2018, 13:57
by Ripa
Janui,
thanks man i will try this...
Do you have an solution for this
evert time my kids play with the Rune display an they change everything in the menu
is there a way to add an password to the menu, that way only with the password you have access to the menu
Ripa
PostPosted: 11 Mar 2018, 12:31
by Ripa
To use RuneAudio, BubbleUPnP and Qobuz, you need an Android pad or phone, and a running RuneAudio unit with UPnP/DLNA enabled, all on the same network. On the Android, install BubbleUPnP. You may select use the free version to start with, you may want to pay for a licensed version later to get rid of the ads, plus some other limitations.
On the top left of the BuppleUPnP app there is a menu, tap on it and you will see RENDERER, LIBRARY and Settings.
Under RENDERER you should see "Local Renderer", which is you Android unit, and "RuneAudioUPnP", which is your RuneAudio player. Select "RuneAudioUPnP".
Open library "Local and Cloud", select Qobuz and enter your credentials.
Browse the Qobuz for music in main bottom right tab Library, add tracks to the middle tab Playlist, tap on an item in the playlist to play it.
This is it, really.
How can i access DLNA, its now switch off
on the settings airplay and DLNA is on but both are not available
thanks
PostPosted: 23 Mar 2018, 18:20
by EZJstef
Hello ,
i am wonder the signification
*of the red number "2" near on the left of the icon menu on playback screen , somebody can help me??
*The lighnning symbol is power supply too low ??
Thanks Stef
PostPosted: 23 Mar 2018, 22:32
by LeighP
I seem to have a red 1 myself.
Weird as never appeared before.
Leigh
PostPosted: 26 Mar 2018, 06:13
by EZJstef
Hi , i found the red number, is the number of addon can be uploaded with new version .....
Stef
