Page 1 of 1
mount local files on extended partition
Posted:
18 Jan 2017, 00:38
by Cully
I have extended the partition to 32Gb . have created folder /home/music and copied music files/folders to /home/music.
How do I now add /home/music as a source or network mount so I can browse the folders.
Or ideally add /home/music as a bookmark on the library screen?
Re: mount local files on extended partition
Posted:
18 Jan 2017, 11:33
by hondagx35
Hi Cully,
On Rune your library has to be in /mnt/MPD/.
You can / should use the provided folder /mnt/MPD/LocalStorage.
Posted:
13 Mar 2017, 21:14
by avgddash
Thanks Support!
I installed Rune on a Raspberry Pi 3 with a Digi+ SPDIF interface a few days ago.
I could not find out where to store music files on the local SD card, and didn't want
to permanently plug in a USB flash drive.
This answer should be in the FAQ, if not the WIKI!
Now I'm playing beautifully from the RP -> SPDIF -> Topping32ex amp.
Thanks,
avg
Posted:
07 Oct 2019, 21:54
by Suppertime
Noob here, trying desperately to access music on the 2nd partition of my 128g sd card.
The advice is to mount the partition to /mnt/MPD/LocalStorage.
Is this possible without a computer running linux? If you only have a Windows PC, would it ever be possible to mount a partition in this way?
Posted:
08 Oct 2019, 15:43
by cmh714
Suppertime wrote:Noob here, trying desperately to access music on the 2nd partition of my 128g sd card.
You would ssh into your Pi and create the mount....google "man mount" for the command and parameters
