Page 1 of 1
HTTP Request to power down Raspberry PI
PostPosted: 05 Aug 2016, 13:10
by ctownj30
Is there an HTTP request I can make that will turn of the RPi using the "Power Down" feature in the Rune UI?
I want to trigger a power down using my home automation system (which will wait a minute, then remove power from the PI). My automation system can make HTTP requests so this seems like an easy way to do it.
Dug around the UI HTML but could not find it.
(before anyone says "why would you want to shut the PI down": the system is in a rarely used vacation home that is prone to power outages - I keep losing high quality SD cards and hoping this helps).
thanks - djm
Re: HTTP Request to power down Raspberry PI
PostPosted: 06 Aug 2016, 16:30
by deenski
Try following the directions here: http://raspberrywebserver.com/cgiscript ... ython.html
And instead of a hello world program, use this:
#!/usr/bin/env python2
import subprocess
print "Content-type: text/html\n\n"
print "<h1>Shutting Down</h1>"
subprocess.call(['shutdown -h now'])
save it as /usr/lib/cgi-bin/shutdown.py
then:
sudo chmod +x /usr/lib/cgi-bin/shutdown.py
I can't be 100% sure this would work, but after a reboot you should be able to navigate to:
http://runeaudio/cgi-bin/shutdown.py
and when you do, it should shutdown... I think... or break a bunch of stuff... IDK... Good luck, and let me know if it works!
PostPosted: 06 Aug 2016, 17:50
by hondagx35
Hi ctownj30,
Yes, the UI sends a post request to "http://your-ip/settings with
name = syscmd and value = poweroff to shutdown
or
name = syscmd and value = poweroff to reboot to reboot your device
PostPosted: 30 Jun 2020, 14:07
by PetitMalin
hondagx35 wrote:Hi ctownj30,
or
Does it still work, with a version 0.5 ?
Because i try to send :
http://IP/syscmd-poweroff
or
http://runeaudio/syscmd-poweroff
I have an error "Bad request"
Thank's in advance
Nop
PostPosted: 30 Jun 2020, 22:24
by hondagx35
an HTTP POST request cannot be sent by using just an URL. (Except for the special case that there are no form fields and that the server doesn't care about the Content-type header.)
What is your intention?
PostPosted: 01 Jul 2020, 08:52
by PetitMalin
Just to integrate it into my home automation.
Before I used on my Synology LMS as a server and PiCorePlayer for my 5 Raspeberrys.
Now on my Syno Audio Station and Rune Audio (Audio Station because GoogleMusic will disappear)
The concept:
For the ignition of a Rasp: A wireless switch (Zigbee protocol) sends a signal to the Jeedom server which, through a script, switches "On" a SonOff switch (modified in ESP8266)for power "On" which starts the Rasp Player. (This part works, autoplay activated in Rune Audio)
In Jeedom a virtual state to toggle "On" (To know if the Rasp in On or OFF in the script)
In Jeedom possibility to do Play, Stop, Next, Previous, Shuffle, Volume UP and Volume Down in virtual command
For the extinction the same button (wireless switch)
The script check if the Rasp is On or Off
And here i need to post a shutdown command (Hence my question)
A ping request verifies the extinction of the Rasp
Toggle the virtual state to "Off"
After that the script turns off SonOff to cut the power
Thank's for your interest, If you have any question...
Nop
