Re: [HELP] AUDIOPHONICS I-Sabre V3 DAC ES9023 TCXO
Posted:
22 Apr 2016, 21:08
by PeteB
I hope you stick around. I read a few of your posts on Xbian, and at some point that experience would be useful here.
At least you have Raspbian under your belt. I started out with Berkely, and got here via Solaris/Sparc, another BSD, Debian, Ubuntu, and now Arch... and I still don't know what I am doing half the time. (and to think I was actually looking forward to Arch, b/c I thought it was closer to plain vanilla than Ubuntu! (...feel free to laugh now).
Posted:
22 Apr 2016, 21:18
by hondagx35
Hi ingohz,
The script is written a little strange. Wonder that the RasPi still has the time to play music.
You are absolutely right and a "little strange" is very friendly.
The script is coded by audiophonics, i only adapted it so rikardo has a working one.
Sorry but i do not have the motivation to do audiophonics work.
Posted:
22 Apr 2016, 21:46
by PeteB
hondagx35 wrote:...
You are absolutely right and a "little strange" is very friendly. ...
I for one feel better now. I thought I was having trouble reading it b/c it was late at night, and I ran out of beer too soon...
Posted:
22 Apr 2016, 21:52
by rikardo1979
ingohz wrote:rikardo1979 wrote:I would like to change the switching time between artist-title and also I would like to see IP address on display instead of runeaudio.local
search for "hostname --fqdn" and replace it with "ip route get 1 | awk '{print $NF;exit}'". This should display the IP instead of the hostname. The script is written a little strange. Wonder that the RasPi still has the time to play music.
thanks, working fine
Feel free to write a better one
Me and many more, we would be more than happy to use it
edit: any idea how to extend time delay between displaying artist-track info?
That is one of the last thing I miss
Posted:
23 Apr 2016, 09:55
by guillaumesej
I have a RPI3 + audiophonics DAC v3, and I've followed the instructions above to have the OLED screen working.
I've picked up the updated script version of v3.
Starting the OLED service doesn't do anything, and when I run
- Code: Select all
python /usr/local/bin/16x2_oled_runeaudio.py
manually,
I get the following error:
- Code: Select all
Traceback (most recent call last):
File "16x2_oled_runeaudio.py", line 36, in <module>
import RPi.GPIO as GPIO
RuntimeError: This module can only be run on a Raspberry Pi!
Any ideas ?
Posted:
23 Apr 2016, 09:57
by rikardo1979
guillaumesej wrote:Hi,
- Code: Select all
manually,
- Code: Select all
Any ideas ?
Hmm, just wondering if there is something different in RPi 3. I have the RPi 2 as that is the best one for audio applications
Posted:
23 Apr 2016, 09:59
by guillaumesej
Found out this may be due to the version of RPi.GPIO version.
Only version 0.6.2 supports the PI3 board.
I'll give it a shot.
Posted:
23 Apr 2016, 10:02
by guillaumesej
So, after upgrading RPi.GPIO to 0.6.2, I get a slightly different error:
- Code: Select all
File "/usr/local/bin/16x2_oled_runeaudio.py", line 258, in <module>
main()
File "/usr/local/bin/16x2_oled_runeaudio.py", line 96, in main
lcd_string(ip_addr,LCD_LINE_2)
File "/usr/local/bin/16x2_oled_runeaudio.py", line 248, in lcd_string
message = message.center(LCD_WIDTH," ")
TypeError: must be a byte string of length 1, not str
And after a reboot, the OLED does display something...
"Goodbye", right after startup.
Posted:
23 Apr 2016, 10:03
by rikardo1979
guillaumesej wrote:Found out this may be due to the version of RPi.GPIO version.
nice one
If not I am sure you get some help from Frank or other guys who lives in Matrix (good with coding)
BTW, get RPi 2 as its better or at least make sure you disable WiFi and BT built in modules
Posted:
23 Apr 2016, 10:04
by rikardo1979
guillaumesej wrote:So, after upgrading RPi.GPIO to 0.6.2, I get a slightly different error:
- Code: Select all
main()
you would need to modify your python script I believe to adapt to different GPIO ?
