Page 1 of 1
Apple Filing Protocol (AFP)
PostPosted: 12 Mar 2017, 02:09
by jesper
Dear Developer,
I have a Time Capsule that I'd like to use as my NAS for streaming my music from to the RuneAudio on RPI 3B, but it doesn't work. I looked around and think it needs Netatalk or something like that, but I found no instructions on the web clear enough so that I could understand how to add this protocol to the RuneOS myself.
It would be very appreciated to get AFP for the RuneAudio! Anyone who know how to add this?
Re: Apple Filing Protocol (AFP)
PostPosted: 12 Mar 2017, 11:48
by hondagx35
Hi jesper,
your Time Capsule should be mountable via cifs without any issues.
Please post your settings and the error message you get.
PostPosted: 12 Mar 2017, 18:50
by jesper
Thanks for your reply. I did try all three login settings in my Time Capsule - With accounts, With a disk password and With device password - and none worked. First off, which of these three are the correct choice?
I have also a MyBookLive and that works instantly with the SMB/CIFS protocol.
Back to the Time Capsule (which, by the way is an Airport Time Capsule):
The following error message is shown using protocol SMB/CIFS + Time Capsule in "With device password" mode:
" Usage: mount [-lhV] mount -a [options] mount [options] [--source] | [--target] mount [options] mount [] Mount a filesystem. Options: -a, --all mount all filesystems mentioned in fstab -c, --no-canonicalize don't canonicalize paths -f, --fake dry run; skip the mount(2) syscall -F, --fork fork off for each device (use with -a) -T, --fstab alternative file to /etc/fstab -i, --internal-only don't call the mount. helpers -l, --show-labels show also filesystem labels -n, --no-mtab don't write to /etc/mtab -o, --options comma-separated list of mount options -O, --test-opts limit the set of filesystems (use with -a) -r, --read-only mount the filesystem read-only (same as -o ro) -t, --types limit the set of filesystem types --source explicitly specifies source (path, label, uuid) --target explicitly specifies mountpoint -v, --verbose say what is being done -w, --rw, --read-write mount the filesystem read-write (default) -h, --help display this help and exit -V, --version output version information and exit Source: -L, --label synonym for LABEL= -U, --uuid synonym for UUID= LABEL= specifies device by filesystem label UUID= specifies device by filesystem UUID PARTLABEL= specifies device by partition label PARTUUID= specifies device by partition UUID specifies device by path mountpoint for bind mounts (see --bind/rbind) regular file for loopdev setup Operations: -B, --bind mount a subtree somewhere else (same as -o bind) -M, --move move a subtree to some other place -R, --rbind mount a subtree and all submounts somewhere else --make-shared mark a subtree as shared --make-slave mark a subtree as slave --make-private mark a subtree as private --make-unbindable mark a subtree as unbindable --make-rshared recursively mark a whole subtree as shared --make-rslave recursively mark a whole subtree as slave --make-rprivate recursively mark a whole subtree as private --make-runbindable recursively mark a whole subtree as unbindable For more details see mount(8)."
The following error message is shown using protocol SMB/CIFS (OS X Share) + Time Capsule in "With device password" mode:
Kind regards,
Jesper
PostPosted: 12 Mar 2017, 23:02
by hondagx35
Please post what you have entered on the sources page.
From the error message, one can see that your settings are wrong.
