mod: click time-knob to temporary show vol-knob in its place
mod: click time-knob to temporarily show vol-knob in its place (by hiding time-knob and cover)
This makes it quicker to change the volume in a smartphone browser where the controls are vertically stacked. Instead of scrolling down to the volume-knob we hide the time-knob and cover which moves the vol-knob up. After 2.5 seconds all controls are automatically visible again.
note: this conflicts with my touch gesture mod. Use the touch gesture mod instead!
Caveats
- This presupposes that you SSH in to your Rune device and edit files there.
- It is a good idea to first make a backup of the files you modify.
- if the the knob circles do not match in position on your screen try tweaking the 5px value in the code below.
Edit this file
You can also browse through the contents of the file online here
https://github.com/RuneAudio/RuneUI/blo ... /runeui.js
First find this line near the top
and and this on a new line above it
Next find the lines
and add these lines above them
Extra step: needed only if you have done mod 4 on this page
find the line
and replace it with
Necessary steps to apply the modifications
First, when you are done editing, save runeui.js
Next we minify the file (i.e. convert it into a more compact file that RuneAudio normally uses)
- Copy all the contents of your modified runeui.js file to the clipboard
- Paste into the editbox at http://gpbmike.github.io/refresh-sf/
- Click the button Javascript on the right side of the editbox. The content is now minified
- Copy all the minified text in the editbox
- Edit the file runeui.min.js (make a backup of it first!) and replace all its contents with the minified text from the clipboard. Then save. Then reload RuneAudio in the browser.
edit: fixed typo in code
Caveats
Edit this file
- Code: Select all
/srv/http/assets/js/runeui.js
- Code: Select all
var GUI = {
- Code: Select all
var knobhide;
Next find the lines
- Code: Select all
// update info and status on Playback tab
function refreshState() {
- Code: Select all
//click time-knob to temp hide, move up vol-knob
$('#countdown-display').click(function(){
$('#time-knob, #cover-art').addClass('hide');
$('#volume-knob').css('margin-top', '5px');
window.setTimeout(unhideknob,2500);
knobhide = 1;
function unhideknob(){
$('#time-knob, #cover-art').removeClass('hide');
$('#volume-knob').css('margin-top', '30px');
knobhide = "";
find the line
- Code: Select all
else { $('#time-knob, #cover-art').removeClass('hide'); }
and replace it with
- Code: Select all
else if (!knobhide) { $('#time-knob, #cover-art').removeClass('hide'); }
