Page 2 of 2
Re: Unable to mount NAS
Posted:
17 Dec 2013, 22:44
by nic
Last night after removing the source name , the green tick appeared . On clicking update mpd database , I get the prompt box 'mpd update , database update started' but no spinning symbol like on Raspyfi . Going to playback then browse there no source directories . I have used the reboot or power down under 'turn off' on the menu . The strange thing is I get the green tick on nas mounts no matter what fileshare protocol is used
cheers
Nic
Posted:
17 Dec 2013, 23:06
by nic
Now getting the same issues as before . I can access the help , credits and turn off tabs . The others when clicked result in eggtimers or 404 messages . This is on a fresh install on a fresh Sandisc SD card and started happening when trying to add a NAS source . Are there reports of others finding their Runeaudio setup works using the beta release ?
cheers
Nic
Posted:
17 Dec 2013, 23:30
by ACX
nic wrote:Now getting the same issues as before . I can access the help , credits and turn off tabs . The others when clicked result in eggtimers or 404 messages . This is on a fresh install on a fresh Sandisc SD card and started happening when trying to add a NAS source . Are there reports of others finding their Runeaudio setup works using the beta release ?
cheers
Nic
Yes, we had positive feedbacks, so I'm sorry you are the first user experimenting this problem. As we are working hard on preparing the next release, please be patient and wait for it. Thank you for helping us testing
Posted:
18 Jan 2014, 11:27
by bassiedt
With mpd database errors I found the following command very useful. ( maybe a good idea to incorporate it in the webUi as well)
tail /var/log/mpd/mpd.log
To have a quick look at mpd log containing all the database entries. This way I found that volumio gets stuck with certain mp3 files because it uses ffmpeg for mp3 indexing which produces an error.
Posted:
18 Jan 2014, 17:11
by ACX
Thank you bassiedt, we constantly use that command when debugging. In the near future we are going to include a handy debugging tool in the RuneUI. We already use an internal one (try point your browser to
http://runeaudio.local/dev.php to see that) but we want to enhance it and make it easy to use for common users.
Posted:
21 Jan 2014, 18:07
by ACX
Hi nic, have you tried the 0.2-beta released yesterday?
