Hi djevlen,
djevlen wrote:Is runeaudio compatible with that setup and can it use digione+kali features to full extent ?
DigiOne and Kali will not work together, see the allo website
https://www.allo.com/sparky/digione.html wrote:The Digione has a galvanic isolator for both power and signals. You do not need an extra isolator. As well, DigiOne has a double relocking of the S/PDIF stream (one of them taking care of metastability and the second one taking care of realigning the data). You do not need another reclocker (like Kali).
Compatibility: RPI only
PSU: Not needed (power is taken from RPI, then we use a isolated DC/DC convertor with filters and LDO)
Not Working With: Sparky, Isolator, Kali
The DigiOne needs a reasonably recent kernel to work. Linux 4.9.63-1 or higher is required, not all Rune images have this. This image will work:
runeaudio-0-5-beta-for-all-raspberry-pi-models-t6532.html#p25819, not sure about the other images.
