Page 1 of 2
ODROID C1+ and native DSD via I2S
Posted:
20 Sep 2016, 14:30
by Andrew_l
Hello guys!
Can anybody answer me: does ODROID C1+ support direct output Native DSD via I2S? The fact is, I have ODROID C1+ with Rune and DAC (Soekris dam 1121) which supports PCM and DSD bouth via I2S bus. I listen any PCM format without issue but instead sound I hear a white noise when I tried to play DSD files. In the settings of Rune I switch on and off 'support DSD' but with no positive result.
I will be gratefull for all prompts.
Andrew
Re: ODROID C1+ and native DSD via I2S
Posted:
21 Sep 2016, 06:06
by smallfat
As I know, DoP only support USB.
smallfat
Posted:
21 Sep 2016, 06:16
by Andrew_l
Hi smallfat!
You are completely right. I can plug my Teac 501 in ODROID via USB and I can listen all DSD files through DoP. But I would like to use I2S bus.
Andrew
Posted:
21 Sep 2016, 08:43
by hondagx35
Hi Andrew_l,
DSD via I2S is not possible!
The I2S pins can be used to output native DSD, but there is no standard for this.
You have to install a special driver for your DAC.
You have to ask the manufacturer if he can supply such a driver for Linux.
Posted:
21 Sep 2016, 21:41
by Andrew_l
Hello Frank!
Thank you for the reply.
As I know many DACs ,like mine, use the following standard scheme of connecting via I2S bus:
I2S PCM data / DSD right data
I2S PCM Word Clock / DSD left data
I2S PCM Bit Clock / DSD Bit Clock
My question is : can ODROID with Rune deliver three DSD signals ,mentioned above, via I2S pins in principle? Maybe ODROID use the other order of pins to deliver DSD signals, so I could switch them to another scheme of connecting or it surely needs a specific driver to pack DSD signals for transmission via I2S?
Andrew
Posted:
22 Sep 2016, 08:36
by hondagx35
Hi Andrew,
Yes it can, but we have to find a driver for it.
Also we have to find a way how to auto switch between we two modes.
Posted:
22 Sep 2016, 17:27
by smallfat
Two modes, means PCM and DSD?
smallfat
hondagx35 wrote:Hi Andrew,
Posted:
22 Sep 2016, 17:32
by hondagx35
Hi smallfat,
Yes.
Posted:
23 Sep 2016, 14:03
by Andrew_l
Hello Frank!
Thank you for your answer. As I understood, need to use something like this
http://bbb.ieero.com please, take a look at it. This driver is a module of kernel and also it's precompiled version of the driver,
so I will not able to get it separately. What do you think, if I ask for this driver to ArchLinux community, could they help me?
Andrew
Posted:
23 Sep 2016, 17:15
by hondagx35
Hi Andrew_l,
this will not work on the RaspberryPi, because the driver is made only for the BeagleBoneBlack.
A few days ago there was a post about a new DAC with I2S/DSD here on the forum.
Try to contact the author and ask him for an Arch Linux driver.
