Page 1 of 1
Cubietruck3 with Amanero usb dac...crumbles, and freezes
PostPosted: 10 Mar 2019, 15:20
by pBuhta
Hello! Please help,
I have Cobietruck 3 and usb Dac with Bolero v3 - on Amanero384 combo USB chip (amanero.com)
and after play I have problems with sound, the sound crumbles, then freezes.
Could this be because of the old core?
I tried another build (other), V.A.M.P. (based on volumio)
And everything works well, fine.
- status from vamp
DAC INFO: 1 [BoleroV3 ]: USB-Audio - BoleroV3 01-00: USB Audio : USB Audio : playback 1
Energy Audio BoleroV3 at usb-1c14000.usb-1, high speed
Kernel INFO: Linux volumio 4.20.2-sunxi #5.73 SMP PREEMPT Sat Jan 26 06:06:10 EST 2019 armv7l GNU/Linux
Alsa lib INFO: #define SND_LIB_VERSION_STR "1.1.7"
MPD INFO: Music Player Daemon 0.20.23
------------from RuneAudio
Debug from runeaudio https://pastebin.com/QwAMqSdy
Can I do something about this? because I used it on the old Dac Runaudio and I would like to use it very much further.
Thanks!!!
Re: Cubietruck3 with Amanero usb dac...crumbles, and freezes
PostPosted: 20 Mar 2019, 17:46
by pBuhta
oh ... maybe there is a way to update the kernel? or instruction ... or how to update rune?
very very thanks!!!
PostPosted: 20 Mar 2019, 23:27
by hondagx35
Hi pBuhta,
updating the kernel is not possible, many things will break.
You can try to edit the /etc/mpd.conf file and change the marked entry:
audio_output {
name "BoleroV3"
type "alsa"
device "plughw:3,0"
auto_resample "no"
auto_format "no"
enabled "yes"
- Get access to the console:
Use SSH from your PC
    If you are not familiar with SSH read this for Windows or this for Linux/MacOS
    The default login for RuneAudio is "root" with the password "rune" (without quotes).
- Use sftp to access files on Rune Audio:
Get WinSCP from here and install it.
When it opens setup the following:
- Session
File Protocol: SCP
Host name: The IP address of your Raspberry Pi
User name: root
Password: rune
That's it, connect and you can transfer files just by dragging and dropping.
PostPosted: 22 Mar 2019, 18:30
by pBuhta
Hi!
i edit file, after I go to the settings mpd page - writes such an error.
screen - http://joxi.ru/D2PDXXeSqYZGQ2
click - edit manually and save - writes what is below
with the problem (the sound crumbles, then freezes) , unfortunately, did not help (
PostPosted: 28 Mar 2019, 16:06
by pBuhta
PostPosted: 31 Mar 2019, 20:49
by pBuhta
PostPosted: 14 Apr 2019, 06:34
by pBuhta
PostPosted: 14 Apr 2019, 15:18
by hondagx35
Hi pBuhta,
after changing the file mpd.conf you should restart the mpd.
systemctl restart mpd
from the console (ssh).
This is only a temporary thing to check the correct settings.
Once you found the correct settings you have to make it permanent (i'll help you with this)
Frank.
PostPosted: 17 Apr 2019, 19:57
by pBuhta
after edit with manualy in web interface -
Warning: socket_write(): unable to write to socket [32]: Broken pipe in /srv/http/app/libs/runeaudio.php on line 105
after
see
File /etc/mpd.conf was modified outside Player UI.
You can edit it manually or reset back to default settings.
I do not have to manually edit the file?
Thanks!!
PostPosted: 19 Apr 2019, 15:13
by pBuhta
