Page 3 of 3
Re: I want to help but don't know how ))
PostPosted: 24 Feb 2015, 15:58
by ACX
bastienauneau wrote:Is that because you mount SMB share locally, and then access it with ocal mounted ath only ?
Yes, we don't use MPD's internal mount method.
bastienauneau wrote:Also, trying to install SMB, with pacman -S samba, I get
:: samba and samba-rune are in conflict. Remove samba-rune? [y/N]
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
That's because we use a lightweight and custom version of smbd:
https://github.com/RuneAudio/RuneOS/blo ... e/PKGBUILD
PostPosted: 09 Mar 2015, 19:34
by bastienauneau
Related to samba, I looked at the issue 13 on github
https://github.com/RuneAudio/RuneOS/issues/13
I whitnessed the same error as described. I did not find anything obvious, so I tried to build the latest 4.2.0. After removing lots of deprecated optons in ./configure, I stumbled on a make error
                                                  : ok
Checking linker accepts -Wl,-no-undefined                                                       : yes
Checking linker accepts ['-undefined', 'dynamic_lookup']                                        : no
Checking linker accepts -Wl,--as-needed                                                         : yes
Checking for -lc not needed        : ok
Checking configure summary        : ok
Checking compiler for PIE support                                                               : yes
Checking compiler for full RELRO support                                                        : yes
Checking for libsystemd-daemon        : yes
Checking for header systemd/sd-daemon.h                                                         : yes
Checking for library systemd-daemon                                                             : yes
Checking compiler accepts ['-fstack-protector']                                                 : yes
Checking linker accepts ['-fstack-protector']                                                   : yes
'configure' finished successfully (16m47.100s)
   Selected embedded Heimdal build
Checking project rules ...
Project rules pass
Unable to find build target matching make
==> ERROR: A failure occurred in build().
    Aborting...
I didnt manage to understand that, and tried to compare with other PKGBUILD on the net, but they all seam very complicated
Then I tried to install 4.2.0 with pacman, and realised it only take 34MB extra
Plus, considering the RPI 2 replacing the RPI, the cpu/mem gain may be less important (or no relevant anymore) compared to effort of supporting a custom build ? So it may be a good move to get back using default samba and smbclient ?
What do you think ?
