TEAC AI-101DA USB working?
Posted:
22 Nov 2016, 11:51
by twinpeaks
I installed RuneAudio on a Raspberry 2. It's working really fine but a separate DAC is needed definitely. Since I also need a new, smaller amp (restricted space), an amp with integrated DAC would be nice. So I found the TEAC AI-101DA. I surely could use the toslink input with a HiFiBerry Digi+ or similar, but using the amp's USB port would be nicer, because no HiFiBerry is needed and both toslink inputs would be free for other sources. I couldn't find a definitive answer, does RuneAudio (or Linux in general) support the USB port of the AI-101DA?
twinpeaks
Re: TEAC AI-101DA USB working?
Posted:
23 Nov 2016, 10:09
by Brain007
i think you need to talk to TEAC official support!
here you go: teac.com/support
Posted:
30 Nov 2016, 14:27
by twinpeaks
Although I didn't expect an answer other than "we don't support Linux" I contacted Teac service last week and asked if they know if this thing works in Linux. No answer at all until now.
I let you know should they still send a reply.
Posted:
01 Mar 2017, 22:50
by VW Darren
I would say -yes.
I have a Teac NP-H750 which has a built in dac I connect to my RPi via a USB cable.
Posted:
02 Mar 2017, 08:06
by ragious
I would say yes to since I run an AD-301DA without problems
Posted:
17 Jan 2020, 06:23
by iosman987
twinpeaks wrote:Hi,
stranger chat USB port would be nicer, because no HiFiBerry is needed and both toslink inputs would be free for other sources. I couldn't find a definitive
stranger chat answer, does RuneAudio (or Linux in general) support the USB port of the AI-101DA?
twinpeaks
Same Issue I'm facing from last month, If you get any solution then please tell me, Thanks In Advanced.
Posted:
08 Jan 2021, 03:10
by numanair
iosman987 wrote:twinpeaks wrote:Hi,
twinpeaks
While this might not be relevant to your setup, I wanted to share that my ai-101da works with linux on a rock64 (SBC similar to a pi). I'm running Armbian 20.11.6 with Alsa. I'm not familiar with runeaudio, so I'm sorry I can't help more specifically.
- Code: Select all
$ cat /proc/asound/cards
0 [rockchiprk3328 ]: rockchip_rk3328 - rockchip,rk3328
rockchip,rk3328
1 [Audio ]: USB-Audio - TEAC AI-101 Audio
TEAC TEAC AI-101 Audio at usb-ff5c0000.usb-1, high speed
