RuneAudio+R e6
Re: RuneAudio+R e6
Postby guermantes » 16 Jan 2021, 19:57
So, next question... :-)
(installed rAudio 1)
Albums that are stored in CD1, CD2, CDxx... folder structures are truncated when moved to playlist. But all files are indexed and in the database because the album view shows tracks from all subfolders with this proper ID3 unique numbering.
Wagner - Der Ring des Nibelungen (Thielemann) 24-96\
---Die Walküre 24-96
---CD1
---CD2
---CD3
---CD4
Only tracks from CD1 gets inserted into the playlist.
For example, the structure with 4 subfolders and 43 tracks total with ID3 track numbers from 1-43 but in each subfolder the files are numbered beginning with 1. I presume that flips mpd up in some sense, and it was like this also when I was using janui's runeAudio 05-beta with your addons, but not when using the runeaudio 05-beta vanilla. So it's something in the @rern implementation that creates this problem. Do you have an idea about how it can be fixed?
RPi 3B with HiFiBerry Digi+ -> Cambridge DACmagic
guermantes
Re: RuneAudio+R e6
Postby kiko » 17 Jan 2021, 00:43
When I rip mulit discʻs I use the ID3 tagging such that disc 1 song one is 01-01, and disc 4 song 10 is 04-10. This way the songs play the way you expect them.
kiko
Re: RuneAudio+R e6
Postby dror » 17 Jan 2021, 09:10
Any way to minimize micro-sd card writings to avoid a failure?
My current experience is a very stable setup (BT works great, mount is detected, web interface responsive), so I would like to preserve this for as long as I can :)
Thanks,
Dror
dror
Re: RuneAudio+R e6
Postby cmh714 » 17 Jan 2021, 17:06
Just take an image of it when you have it all setup. That way you just put it on a new card.
Re: RuneAudio+R e6
Postby dror » 18 Jan 2021, 07:57
cmh714 wrote:Just take an image of it when you have it all setup. That way you just put it on a new card.
Thanks, but what I meant is I prefer avoiding a corrupt card.. seems to happen too occasional to me
dror
Re: RuneAudio+R e6
Postby eziodavinci » 18 Jan 2021, 11:28
Hi everyone,
I have problem with accessing SD card. I cannot click to go inside SD card to browse my library. I try to flash again 2-3 times but no help. Does anyone facing to similar problem?
Thank you in advance.
https://www.upsieutoc.com/image/8FJoGp
eziodavinci
Re: RuneAudio+R e6
Postby rern » 19 Jan 2021, 09:24
dror wrote:Any way to minimize micro-sd card writings to avoid a failure?
Backup Micro SD Card to Image File
rAudio @ https://github.com/rern/rAudio-1
Raspberry Pi 3B > SMSL M8 DAC
Re: RuneAudio+R e6
Postby dror » 19 Jan 2021, 12:00
As I answered @cmh714 suggestion, my intention was to reduce the micro-sd card writes, to avoid a failure. The backup is nice, but I want to prevent a corrupt SD (happened to me too occasionally).
I remember there was a discussion about this with instructions, but I can't find it, nor could I be sure this would work with your build.
Dror
dror
Re: RuneAudio+R e6
Postby rastus » 20 Jan 2021, 03:04
So this is the latest rern version?
rastus
Re: RuneAudio+R e6
Postby cycl157 » 20 Jan 2021, 03:46
rastus wrote:So this is the latest rern version?
Latest version information can be found here: https://github.com/rern/rAudio-1
Latest announcements and discussions can be found here: https://github.com/rern/rAudio-1/discussions
cycl157
