RuneAudio+R e6
Re: RuneAudio+R e6
Postby RolandBlaze » 24 Oct 2020, 14:48
kiko wrote:MPD is getting partially through scanning the media shares and will end up with:
Oct 22 14:15 : exception: error on client 93: Output buffer is full
Oct 22 14:15 : exception: No such directory
I have a large collection also and just noticed i have the same issue on a watching output of a full scan on a complete rebuild from scratch today.
Oct 24 14:43:24 runeaudio taskset[402]: exception: error on client 483: Output buffer is full
RuneAudio+R e6 20201108 
Raspberry Pi 4 Model B Rev 1.
RolandBlaze
Re: RuneAudio+R e6
Postby R101 » 24 Oct 2020, 16:16
rern wrote:
R101 wrote:...
The /etc/netctl/SSID file which is saved in backup.gz is not the current one, but the one which was last restored. If I edit the profile in /etc/netctl, the changed file is not saved in the backup. I think this might be the case for some other files as well.
It seems like there's no need to restore Wi-Fi data because RuneAudio Wi-Fi has connected already to be able to restore. So it should be removed.
That seems a good solution, rern. Presumably the file created from /boot/wifi is overwritten when the settings are restored?
Re: RuneAudio+R e6
Postby RolandBlaze » 24 Oct 2020, 18:13
@Rern
There's a problem with output mpc listall command for a very large Library, might be 30,000 tracks or more.
Please post results of:
mpc listall | wc -l
mpc list album | wc -l
mpc listall | wc -l
MPD error: Connection closed by the server
0
12728
Since generating thumbnails for all the albums and then starting from scratch with the latest image I cannot get my mpd to finish scanning my NAS, and get the error below at the end of scanning and the library icon is left flashing but nothing listed in library, only option is to restart mpd /rune and it will start scanning again.. and fail etc.. stuck in a loop :(
Appears as if MPD cannot handle the size of db after the extra added data with the thumbnails /covers/etc now:
Oct 24 18:01:12 runeaudio taskset[1238]: exception: error on client 330: Output buffer is full
Oct 24 18:02:08 runeaudio taskset[1238]: exception: error on client 336: Output buffer is full
Oct 24 18:02:10 runeaudio taskset[1238]: exception: error on client 337: Output buffer is full
RolandBlaze
Re: RuneAudio+R e6
Postby s.k. » 24 Oct 2020, 19:34
RolandBlaze wrote:There's a problem with output mpc listall command for a very large Library, might be 30,000 tracks or more.
mpc listall | wc -l
mpc listall | wc -l
0
12728
Same problem here.
I have bypassed the error with this suggestion.
https://www.runeaudio.com/forum/tuning-of-mpd-output-buffer-t1053.html
How can I rescan the albums without rebuild the library ?
@ rern
Is this normal ?
RPi2B Rev 1.1, Allo DigiOne, ATXRaspi, 16x2 OLED display - running rAudio
s.k.
Re: RuneAudio+R e6
Postby RolandBlaze » 24 Oct 2020, 19:47
Same problem here.
@s.k. Thanks bud. Have already tried "16384", but that failed so have now changed to "32768". But will take a while to rescan again to see if works.
RolandBlaze
Re: RuneAudio+R e6
Postby s.k. » 24 Oct 2020, 20:03
I also had "16384" but I have used "45056" :D
My scan have finished - the Albums are visible :!:
@ rern
A tweak button for very large collections seams good idea
s.k.
Re: RuneAudio+R e6
Postby kiko » 25 Oct 2020, 00:54
I have set max_output_buffer_size "49152" and stil get Output buffer is full.
Any more ideas on what to change?
kiko
Re: RuneAudio+R e6
Postby rern » 25 Oct 2020, 09:29
@RolandBlaze, @s.k. and @kiko,
Please try:
- Download a revised update script:
wget https://github.com/rern/RuneAudio-Re6/raw/UPDATE/srv/http/bash/cmd-list.sh -O /srv/http/bash
- Library > NAS or USB > go to an album track list
- Coverart context menu > Update database
rAudio @ https://github.com/rern/rAudio-1
Raspberry Pi 3B > SMSL M8 DAC
Re: RuneAudio+R e6
Postby Beelzebassie » 25 Oct 2020, 20:48
rern wrote:
I assume part of the syntax was missing; added "/cmd-list.sh" to it.
For me, the database now updates within 5 minutes. Thanx!
Beelzebassie
Re: RuneAudio+R e6
Postby rern » 26 Oct 2020, 06:04
Beelzebassie wrote:
rern wrote:
Sorry.
Now it's included in today's update.
Please remove the buffer tweak and update Library again.
