Hi Guys,
Any chance of knowing if 0.3-beta is coming out soon?
Any aupdate is kindly appreciated!
Cheers,
Chanh
by Chanh » 29 Sep 2014, 10:03
by Woodhouse » 02 Oct 2014, 07:48
by J@r0d » 03 Oct 2014, 03:56
#change wlan0 to your wireless device
interface=wlan0
driver=nl80211
ssid=test
channel=1
[root@runeaudio ~]# nano ~/hostapd-test.conf
[root@runeaudio ~]# hostapd ~/hostapd-test.conf
Configuration file: /root/hostapd-test.conf
nl80211: Could not configure driver mode
nl80211 driver initialization failed.
hostapd_free_hapd_data: Interface wlan0 wasn't started
[root@runeaudio ~]#
Using interface wlan0 with hwaddr 7c:dd:90:5f:cxx:xx and ssid "test"
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
handle_probe_req: send failed
by J@r0d » 03 Oct 2014, 09:12
● netctl@wlan0.service - wlan0 connection
Loaded: loaded (/etc/systemd/system/netctl@wlan0.service; enabled)
Active: failed (Result: exit-code) since Thu 1970-01-01 00:03:38 UTC; 8min ago
Docs: man:netctl.profile(5)
Process: 1345 ExecStart=/usr/lib/network/network start %I (code=exited, status=1/FAILURE)
Main PID: 1345 (code=exited, status=1/FAILURE)
[root@runeaudio system]#
[root@runeaudio system]# netctl status wlan0
Active: activating (start) since Thu 1970-01-01 00:12:59 UTC; 19s ago
Main PID: 1930 (network)
CGroup: /system.slice/system-netctl.slice/netctl@wlan0.service
├─1930 /bin/bash /usr/lib/network/network start wlan0
├─1936 wpa_supplicant -B -P /run/wpa_supplicant_wlan0.pid -i wlan0 -D nl80211,wext -c/etc/wpa_supplicant/wpa_supplicant.conf
└─2286 sleep 0.2
[root@runeaudio system]# hostapd ~/hostapd-test.conf
Using interface wlan0 with hwaddr 7c:dd:90:5f:xx:xx and ssid "test"
wlan0: AP-ENABLED
by challenge » 05 Oct 2014, 14:43
by Peter » 07 Oct 2014, 08:12
franz159 wrote:Is there any ETA for the 0.3 beta and 0.4 releases?
Respectively at begin and end of october, hopefully
by Aquarius » 08 Oct 2014, 10:01
by Peter » 08 Oct 2014, 10:03
by Peter » 08 Oct 2014, 10:15
by Devox » 08 Oct 2014, 12:39
support RuneAudio
