Right.jlynton wrote:Thanks Janui, I will do so as soon as it stops again, and post the result. I do not need to run the commands as su, right?
by janui » 11 Oct 2018, 20:03
by popov » 12 Oct 2018, 16:16
by jlynton » 14 Oct 2018, 16:54
root@runeaudio(rw):~# systemctl stop shairport-sync
root@runeaudio(rw):~# systemctl stop avahi-daemon
Job for avahi-daemon.service canceled.
root@runeaudio(rw):~# systemctl start avahi-daemon
root@runeaudio(rw):~# systemctl start shairport-sync
by janui » 14 Oct 2018, 17:29
From this, it would seem that Rune is working correctly, but somehow your PC is 'forgetting' the link to the IP address. If it’s a Windows PC you could try deinstalling and reinstalling Bonjour (reboot after deinstalling). You can download it from the Apple site here: https://support.apple.com/downloads just search for Bonjour. It is called ‘Bonjour Print Services for Windows v2.0.2’.jlynton wrote:It still did not work, but after rebooting my PC it did. The whole time that runeaudio.local did not work, I was able to connect using the pi's (fixed) IP, I was also able to connect using the RuneAudio android app (where I have NOT entered the pi's IP).
by jlynton » 14 Oct 2018, 19:05
janui wrote:...From this, it would seem that Rune is working correctly, but somehow your PC is 'forgetting' the link to the IP address. If it’s a Windows PC you could try deinstalling and reinstalling Bonjour (reboot after deinstalling). You can download it from the Apple site here: https://support.apple.com/downloads just search for Bonjour. It is called ‘Bonjour Print Services for Windows v2.0.2’.
systemctl restart avahi-daemon
by popov » 14 Oct 2018, 21:19
by janui » 15 Oct 2018, 10:43
That is interesting, so it seems to be related to dhcpcd. This command should show what your linux client can see:popov wrote:On linux restarting dhcpcd "solve", but not explain
avahi-browse -atrlkp
by jlynton » 15 Oct 2018, 15:11
avahi-browse-atrlkp
+;enp4s0;IPv4;RUNEAUDIO;_smb._tcp;local
+;enp4s0;IPv4;runeaudio;_mpd._tcp;local
=;enp4s0;IPv4;RuneAudio\032\091runeaudio\093\032\091b8\05827\058eb\05867\05861\0585e\093;_http._tcp;local;runeaudio.local;10.24.57.35;80;"runeos_version=0.5-gearhead-janui" "skin_name=RuneUI"
=;enp4s0;IPv4;RUNEAUDIO;_smb._tcp;local;runeaudio.local;10.24.57.35;445;
=;enp4s0;IPv4;runeaudio;_mpd._tcp;local;runeaudio.local;10.24.57.35;6600;
jeremy@jeremy ~ $
root@runeaudio(rw):~# systemctl restart avahi-daemon
by popov » 15 Oct 2018, 19:00
by Pushok62 » 15 Oct 2018, 21:18
support RuneAudio
