Rasperri Pi + Runeaudio + LCD I2C 2004 20x4
Postby dom_france » 19 Feb 2018, 23:17
First, I would like to thank you for this update version (this image) :
RuneAudio_rpi2_rp3_0.4-beta_20170229_2GB.img.gz
I tried it this week end, because, I would like to automatically play a playlist with MPC and a service when my Raspberri switch on, and with this image, OK for me.
After, I transfer a python script (name shutdown.pi) to switch off my rasperry pi 3, OK, very good too, my solution is OK.
Now, I would like to add a display, with I2C protocole, like LCD I2C 2004 20x4, and I need your help, because I can not start the order "i2cdetect -y 1" to scrut my electronic editing.
Thank you per Advance
Dom (from France)
RQ : sorry for my english, I'm french...
My question :
Raspberry Pi 3 + RuneAudio_rpi2_rp3_0.4-beta_20170229_2GB.img.gz + display LCD with I2C : how to do ?
Bye Bye
dom_france
Re: Rasperri Pi + Runeaudio + LCD I2C 2004 20x4
Postby hondagx35 » 20 Feb 2018, 00:10
Hi Dom,
what is your exact problem?
To get I2C working you have to enable it in "/boot/config.txt" first
    dtparam=i2c1=on
    dtparam=i2c_arm=on
Next you have to install I2C-Tools :
pacman -S i2c-tools
And check this
http://www.runeaudio.com/forum/lcd-display-and-buttons-in-python-tutorial-and-code-t1191.html?hilit=i2c%20display
Postby dom_france » 20 Feb 2018, 19:22
thank you for your answer.
First, I change my system file "/boot/config.txt" with "nano" and I added this :
dtparam=i2c1=on
dtparam=i2c_arm=on
install I2c-tools OK for me, like this :
And check this
Now, I'm going to read this post :
and in the coming days, I'll come back to you if I have problems
thank you....
Bye
DOM from France
dom_france
Postby dom_france » 20 Feb 2018, 20:25
After install "i2c-tools" with pacman -S
I try this command to scrut my "I2C network", but without success :
i2cdetect -y 1
I have this error :
Error: Could not open file `/dev/i2c-1' or `/dev/i2c/1': No such file or directory
here is my screenshot :
why ?
in /dev directory, I don't see any module with "i2c"...
dom_france
Postby dom_france » 21 Feb 2018, 21:58
Hello everybody,
today, I try to install "gcc" (because Adafruit library need gcc) but without success : no space enough on my system :
it's strange because my SD card is a 16GB... only 2GB for system...
Can someone help me step by step for the establishment of my display?
Thank you...
DOM
I use this version : RuneAudio_rpi2_rp3_0.4-beta_20170229_2GB.img.gz
because I wanted these 5 points:
1) autoplay at startup (on usbkey with lots of music folder
2) GPIO management OK
3) button shutdown (electric)
4) random reading at startup
5) I2C display
my last point (5) is difficult for me, please help me...
Bye
dom_france
Postby hondagx35 » 21 Feb 2018, 22:14
Hi Dom,
This is normal, you have to expand your file system:
fdisk /dev/mmcblk0
Delete the second partition /dev/mmcblk0p2
d
2
Create a new primary partition and use default sizes prompted. This will then create a partiton that fills the disk
n
p
2
enter
enter
Save and exit fdisk:
w
Now reboot. Once rebooted:
resize2fs /dev/mmcblk0p2
Postby dom_france » 21 Feb 2018, 22:40
OK, My computer's software is LINUXMINT,
I use Gparted, and now, gcc is OK on my raspberry...
and space OK on my SD:
and now ?
I2C-tools ok, but ii2cdetect -y 1 no work....
see you later...
Bye
thank you
dom_france
Postby dom_france » 22 Feb 2018, 18:42
in this forum how-to-enable-i2c-t1287.html, I see this :
3) Open /etc/modules-load.d/raspberrypi.conf with:
nano /etc/modules-load.d/raspberrypi.conf
And add this at the end:
i2c-bcm2708
i2c-dev
But I don't have a file name "raspberrypi.conf in /etc/modules-load.d...
My Raspberry is a raspberry pi 3 Model B.
A+++
dom_france
Postby dom_france » 22 Feb 2018, 20:57
Tonight I try this with success, but I'm no sure :
I make a new file in /etc/modules-load.d with this name : i2c.conf
I edited this file with "nano /etc/modules-load.d/i2c.conf" and I put this (and only this) : i2c-dev
I save and quit this file.
Then, i type this : modprobe i2c-dev
and finally, i2cdetect -y 1 ok :
but I'm no sure...
is it normal that I have the past by creating a file in /etc/modules-load.d ?
dom_france
Postby dom_france » 22 Feb 2018, 21:00
WIth this order "lsmod | grep i2c", I get this :
... Normal ?
OK or NOT OK ?
dom_france
