hondagx35 wrote:For now, you can try to enable it so it starts on boot:
- Code: Select all
systemctl enable smbd
I tried this, but no result, getting crazy of it
By the way, is there any name and password required for connecting samba?
by johnberg » 03 Aug 2017, 11:10
- Code: Select all
by kolia » 05 Aug 2017, 08:49
diw wrote:No Audio and system hang with Digi+ pro and Raspberry pi 3.
I am using the latest image “RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB” with Rasberry pi 3 and Digi+ pro.
When I play any song there is no audio and system hangs “MPD Setting -> Audio output interface -> interfaceHiFiBerry Digi (I²S)”.
If I choose MPD Setting “MPD Setting -> Audio output interface Rasberry Pi HDMI Output”, then there is sound.
I tried Volumio and it work fine with Digi+ pro in the same system.
- Code: Select all
logs
###### System info ######
Linux version 4.1.20-1-ARCH (builduser@leming) (gcc version 5.3.0 (GCC) ) #1 SMP Sat Mar 19 20:07:23 MDT 2016
system time: Mon Feb 22 15:40:29 CET 2016
system load: 0.70 0.16 0.05 1/150 785
HW platform: RaspberryPi2 (08)
playerID: 08b26fff2ac4ddac6fee7fbbc1890504ae
###### System load statistics (procinfo -H) ######
Memory: Total Used Free Buffers
RAM: 922.67MiB 223.34MiB 699.33MiB 17.40MiB
Swap: 0.00B 0.00B 0.00B
Bootup: Mon Feb 22 15:40:03 2016 Load average: 0.70 0.16 0.05 1/152 787
user : 00:00:05.29 5.1% page in : 136597
nice : 00:00:01.45 1.4% page out: 740
system: 00:00:09.80 9.5% page act: 10891
IOwait: 00:00:25.55 24.8% page dea: 0
hw irq: 00:00:00.00 0.0% page flt: 134794
sw irq: 00:00:00.17 0.2% swap in : 0
idle : 00:01:00.82 59.0% swap out: 0
uptime: 00:00:25.86 context : 53024
irq 16: 0 irq 65: 19
irq 20: 0 irq 66: 2
irq 21: 0 irq 75: 1
irq 24: 0 irq 77: 3186
irq 29: 298 irq 79: 17
irq 31: 2 irq 82: 119
irq 32: 8314 irq 84: 8136
irq 49: 0 irq 96: 0
irq 50: 0 irq 97: 6312
mmcblk0 3138r mmcblk0p2 3040r
mmcblk0p1 59r
eth0 TX 81.77KiB RX 32.13KiB wlan0 TX 0.00B RX 3.79KiB
lo TX 167.34KiB RX 167.34KiB
###### Active processes (pstree) ######
systemd-+-2*[agetty]
|-avahi-daemon---avahi-daemon
|-cmd_async---sh---sudo---xinit-+-Xorg-+-{llvmpipe-0}
| | |-{llvmpipe-1}
| | |-{llvmpipe-2}
| | `-{llvmpipe-3}
| `-sh-+-matchbox-window
| `-midori
|-cmd_async---sh---debug_collector---sh---pstree
|-dbus-daemon
|-devmon---udevil
|-dhcpcd
|-ifplugd
|-mpd-+-{decoder}
| |-{io}
| |-{output:snd_rpi_}
| `-{player}
|-nginx---nginx
|-nmbd
|-ntpd---{ntpd}
|-php-fpm---3*[php-fpm]
|-redis-server---2*[{redis-server}]
|-rune_PL_wrk
|-rune_SY_wrk
|-sh---sleep
|-shairport---{shairport}
|-smbd---smbd
|-sshd
|-systemd-journal
|-systemd-resolve
|-systemd-udevd
|-upmpdcli---10*[{upmpdcli}]
|-wpa_supplicant
`-xbindkeys
###### Audio backend ######
Advanced Linux Sound Architecture Driver Version k4.1.20-1-ARCH.
Card list: (/proc/asound/cards)
0 [ALSA ]: bcm2835 - bcm2835 ALSA
bcm2835 ALSA
1 [sndrpihifiberry]: snd_rpi_hifiber - snd_rpi_hifiberry_digi
PLAYBACK devices: (aplay -l)
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 1: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HifiBerry Digi HiFi wm8804-spdif-0 []
Subdevices: 1/1
PCM devices: (aplay -L)
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
sysdefault:CARD=ALSA
default:CARD=sndrpihifiberry
snd_rpi_hifiberry_digi,
sysdefault:CARD=sndrpihifiberry
Simple mixer controls: (amixer scontrols)
card 0:
Simple mixer control 'PCM',0
card 1:
Simple mixer control 'Tx Source',0
Mixer controls: (amixer controls)
card 0:
numid=3,iface=MIXER,name='PCM Playback Route'
numid=2,iface=MIXER,name='PCM Playback Switch'
numid=1,iface=MIXER,name='PCM Playback Volume'
numid=5,iface=PCM,name='IEC958 Playback Con Mask'
numid=4,iface=PCM,name='IEC958 Playback Default'
card 1:
numid=1,iface=MIXER,name='Tx Source'
MPD audio outputs status: (mpc outputs)
Output 1 (bcm2835 ALSA_1) is disabled
Output 2 (bcm2835 ALSA_2) is disabled
Output 3 (snd_rpi_hifiberry_digi) is enabled
###### mpd version ######
mpd version: 0.19.0
###### mpd.conf ######
# Auto generated mpd.conf file
# please DO NOT edit it manually!
# Use RuneUI MPD config section
log_level "default"
log_file "/var/log/runeaudio/mpd.log"
state_file "/var/lib/mpd/mpdstate"
zeroconf_enabled "yes"
zeroconf_name "runeaudio"
bind_to_address "/run/mpd.sock"
bind_to_address "any"
port "6600"
max_connections "20"
user "mpd"
group "audio"
db_file "/var/lib/mpd/mpd.db"
sticker_file "/var/lib/mpd/sticker.sql"
pid_file "/var/run/mpd/pid"
music_directory "/mnt/MPD"
playlist_directory "/var/lib/mpd/playlists"
follow_outside_symlinks "yes"
follow_inside_symlinks "yes"
auto_update "no"
filesystem_charset "UTF-8"
id3v1_encoding "UTF-8"
volume_normalization "no"
audio_buffer_size "2048"
buffer_before_play "20%"
gapless_mp3_playback "yes"
mixer_type "disabled"
input {
plugin "curl"
decoder {
plugin "ffmpeg"
enabled "yes"
replaygain "off"
audio_output {
name "bcm2835 ALSA_1"
type "alsa"
device "hw:0,0"
auto_resample "no"
auto_format "no"
audio_output {
name "bcm2835 ALSA_2"
type "alsa"
device "hw:0,0"
auto_resample "no"
auto_format "no"
audio_output {
name "snd_rpi_hifiberry_digi"
type "alsa"
device "hw:1,0"
auto_resample "no"
auto_format "no"
enabled "yes"
###### Kernel optimization parameters ######
hardware platform: RaspberryPi2
current orionprofile: ACX
kernel scheduler for mmcblk0: [noop] deadline cfq bfq
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 18000000
/proc/sys/kernel/sched_rt_period_us: 1000000
/proc/sys/kernel/sched_rt_runtime_us: 950000
/proc/sys/kernel/sched_autogroup_enabled: 1
/proc/sys/kernel/sched_rr_timeslice_ms: 10
/proc/sys/kernel/sched_min_granularity_ns: 2250000
/proc/sys/kernel/sched_wakeup_granularity_ns: 3000000
###### Kernel module snd_usb_audio settings ######
Error opening module snd_usb_audio
###### Systemd active startup scripts (ls -lah /etc/systemd/system/multi-user.target.wants/) ######
total 8.0K
drwxr-xr-x 2 root root 4.0K Mar 21 2016 .
drwxr-xr-x 6 root root 4.0K Mar 13 2016 ..
lrwxrwxrwx 1 root root 44 Feb 15 2015 avahi-daemon.service -> /usr/lib/systemd/system/avahi-daemon.service
lrwxrwxrwx 1 root root 39 Feb 8 2015 haveged.service -> /usr/lib/systemd/system/haveged.service
lrwxrwxrwx 1 root root 44 Mar 11 2016 mpd-watchdog.service -> /usr/lib/systemd/system/mpd-watchdog.service
lrwxrwxrwx 1 root root 44 Mar 21 2016 netctl-auto@wlan0.service -> /usr/lib/systemd/system/netctl-auto@.service
lrwxrwxrwx 1 root root 47 Mar 13 2016 netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 37 Feb 14 2015 nginx.service -> /usr/lib/systemd/system/nginx.service
lrwxrwxrwx 1 root root 36 Feb 15 2015 ntpd.service -> /usr/lib/systemd/system/ntpd.service
lrwxrwxrwx 1 root root 39 Feb 14 2015 php-fpm.service -> /usr/lib/systemd/system/php-fpm.service
lrwxrwxrwx 1 root root 37 Feb 14 2015 redis.service -> /usr/lib/systemd/system/redis.service
lrwxrwxrwx 1 root root 40 Mar 19 2016 remote-fs.target -> /usr/lib/systemd/system/remote-fs.target
lrwxrwxrwx 1 root root 43 Feb 14 2015 rune_PL_wrk.service -> /usr/lib/systemd/system/rune_PL_wrk.service
lrwxrwxrwx 1 root root 45 Feb 14 2015 rune_shutdown.service -> /usr/lib/systemd/system/rune_shutdown.service
lrwxrwxrwx 1 root root 43 Feb 14 2015 rune_SY_wrk.service -> /usr/lib/systemd/system/rune_SY_wrk.service
lrwxrwxrwx 1 root root 36 Feb 8 2015 sshd.service -> /usr/lib/systemd/system/sshd.service
lrwxrwxrwx 1 root root 48 Feb 8 2015 systemd-resolved.service -> /usr/lib/systemd/system/systemd-resolved.service
###### Filesystem mounts ######
/dev/root / ext4 rw,relatime,data=ordered 0 0
devtmpfs /dev devtmpfs rw,relatime,size=468104k,nr_inodes=117026,mode=755 0 0
sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0
securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /run tmpfs rw,nosuid,nodev,mode=755 0 0
tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0
cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0
cgroup /sys/fs/cgroup/bfqio cgroup rw,nosuid,nodev,noexec,relatime,bfqio 0 0
cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0
cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0
cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0
cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0
cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=33,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0
debugfs /sys/kernel/debug debugfs rw,relatime 0 0
mqueue /dev/mqueue mqueue rw,relatime 0 0
tmpfs /tmp tmpfs rw 0 0
configfs /sys/kernel/config configfs rw,relatime 0 0
logs /var/log tmpfs rw,nosuid,nodev,noatime,size=5120k 0 0
rune-logs /var/log/runeaudio tmpfs rw,nosuid,nodev,noatime,size=5120k 0 0
/dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro 0 0
###### Filesystem mounts - free space (df -h) ######
Filesystem Size Used Avail Use% Mounted on
/dev/root 1.9G 1.6G 186M 90% /
devtmpfs 458M 0 458M 0% /dev
tmpfs 462M 0 462M 0% /dev/shm
tmpfs 462M 6.2M 456M 2% /run
tmpfs 462M 0 462M 0% /sys/fs/cgroup
tmpfs 462M 8.0K 462M 1% /tmp
logs 5.0M 24K 5.0M 1% /var/log
rune-logs 5.0M 36K 5.0M 1% /var/log/runeaudio
/dev/mmcblk0p1 100M 18M 83M 18% /boot
###### Loaded kernel modules ######
Module Size Used by
brcmfmac 187227 0
brcmutil 8240 1 brcmfmac
cfg80211 476512 1 brcmfmac
snd_soc_wm8804_i2c 1670 1
snd_soc_wm8804 8304 1 snd_soc_wm8804_i2c
snd_soc_hifiberry_digi 3593 0
snd_soc_bcm2708_i2s 6965 2
regmap_i2c 2864 1 snd_soc_wm8804_i2c
regmap_mmio 3193 1 snd_soc_bcm2708_i2s
snd_soc_core 158424 3 snd_soc_wm8804,snd_soc_hifiberry_digi,snd_soc_bcm2708_i2s
i2c_bcm2708 5776 0
snd_compress 8154 1 snd_soc_core
bcm2835_gpiomem 3522 0
snd_pcm_dmaengine 5232 1 snd_soc_core
bcm2835_rng 2031 0
uio_pdrv_genirq 3343 0
uio 9033 1 uio_pdrv_genirq
sch_fq_codel 7328 3
snd_bcm2835 21874 0
snd_pcm 86717 4 snd_bcm2835,snd_soc_wm8804,snd_soc_core,snd_pcm_dmaengine
snd_timer 21835 1 snd_pcm
snd 62709 5 snd_bcm2835,snd_soc_core,snd_timer,snd_pcm,snd_compress
bcm2708_rng 1171 0
rng_core 8022 2 bcm2835_rng,bcm2708_rng
ip_tables 12167 0
x_tables 16543 1 ip_tables
ipv6 356958 0
###### Network listening sockets (netstat -lnp) ######
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 382/smbd
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 272/redis-server 12
tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN 265/systemd-resolve
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 285/nginx: master p
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 285/nginx: master p
tcp 0 0 0.0.0.0:82 0.0.0.0:* LISTEN 285/nginx: master p
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 266/sshd
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 382/smbd
tcp 0 0 0.0.0.0:49152 0.0.0.0:* LISTEN 437/upmpdcli
tcp 0 0 0.0.0.0:6600 0.0.0.0:* LISTEN 434/mpd
tcp 0 0 0.0.0.0:5002 0.0.0.0:* LISTEN 445/shairport
udp 0 0 192.168.2.26:123 0.0.0.0:* 279/ntpd
udp 0 0 127.0.0.1:123 0.0.0.0:* 279/ntpd
udp 0 0 0.0.0.0:123 0.0.0.0:* 279/ntpd
udp 0 0 0.0.0.0:42620 0.0.0.0:* 223/avahi-daemon: r
udp 0 0 192.168.2.255:137 0.0.0.0:* 390/nmbd
udp 0 0 192.168.2.26:137 0.0.0.0:* 390/nmbd
udp 0 0 0.0.0.0:137 0.0.0.0:* 390/nmbd
udp 0 0 192.168.2.255:138 0.0.0.0:* 390/nmbd
udp 0 0 192.168.2.26:138 0.0.0.0:* 390/nmbd
udp 0 0 0.0.0.0:138 0.0.0.0:* 390/nmbd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 223/avahi-daemon: r
udp 0 0 0.0.0.0:5355 0.0.0.0:* 265/systemd-resolve
udp 0 0 0.0.0.0:1900 0.0.0.0:* 437/upmpdcli
udp 0 0 127.0.0.1:46582 0.0.0.0:* 437/upmpdcli
udp 0 0 0.0.0.0:68 0.0.0.0:* 558/dhcpcd
Active UNIX domain sockets (only servers)
Proto RefCnt Flags Type State I-Node PID/Program name Path
unix 2 [ ACC ] SEQPACKET LISTENING 7433 1/init /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 13581 496/php-fpm: master /var/run/php-display.sock
unix 2 [ ACC ] STREAM LISTENING 13584 496/php-fpm: master /var/run/php-db.sock
unix 2 [ ACC ] SEQPACKET LISTENING 7442 1/init /run/systemd/coredump
unix 2 [ ACC ] STREAM LISTENING 13587 496/php-fpm: master /var/run/php-command.sock
unix 2 [ ACC ] STREAM LISTENING 11292 272/redis-server 12 /tmp/redis.sock
unix 2 [ ACC ] STREAM LISTENING 14782 514/Xorg @/tmp/.X11-unix/X0
unix 2 [ ACC ] STREAM LISTENING 10867 1/init /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 10870 1/init /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 10872 1/init /run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 13756 390/nmbd /var/run/samba/nmbd/unexpected
unix 2 [ ACC ] STREAM LISTENING 14783 514/Xorg /tmp/.X11-unix/X0
unix 2 [ ACC ] STREAM LISTENING 7401 1/init /run/systemd/private
unix 2 [ ACC ] STREAM LISTENING 13553 434/mpd /run/mpd.sock
unix 2 [ ACC ] STREAM LISTENING 7417 1/init /run/systemd/journal/stdout
###### Network established sockets (netstat -np) ######
Active Internet connections (w/o servers)
tcp 0 0 127.0.0.1:57605 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:57564 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:57745 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:57670 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:57661 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:57442 127.0.0.1:6379 TIME_WAIT -
Active UNIX domain sockets (w/o servers)
unix 2 [ ] DGRAM 11684 382/smbd /var/lib/samba/private/msg.sock/382
unix 2 [ ] DGRAM 8787 260/wpa_supplicant /run/wpa_supplicant/wlan0
unix 2 [ ] DGRAM 7825 260/wpa_supplicant /run/wpa_supplicant/p2p-dev-wlan0
unix 2 [ ] DGRAM 13496 390/nmbd /var/lib/samba/private/msg.sock/390
unix 2 [ ] DGRAM 12524 388/smbd /var/lib/samba/private/msg.sock/388
unix 3 [ ] DGRAM 7399 1/init /run/systemd/notify
unix 6 [ ] DGRAM 7413 1/init /run/systemd/journal/dev-log
unix 5 [ ] DGRAM 7419 1/init /run/systemd/journal/socket
unix 3 [ ] STREAM CONNECTED 14484 437/upmpdcli
unix 3 [ ] STREAM CONNECTED 10057 265/systemd-resolve
unix 3 [ ] STREAM CONNECTED 12154 507/php
unix 3 [ ] STREAM CONNECTED 9951 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 15417 723/matchbox-window
unix 3 [ ] STREAM CONNECTED 15021 272/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 11065 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 14498 225/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 10887 1/init
unix 3 [ ] STREAM CONNECTED 13558 434/mpd
unix 3 [ ] STREAM CONNECTED 17402 272/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 8525 160/systemd-udevd
unix 3 [ ] STREAM CONNECTED 12871 496/php-fpm: master
unix 3 [ ] STREAM CONNECTED 15436 434/mpd /run/mpd.sock
unix 3 [ ] STREAM CONNECTED 13579 496/php-fpm: master
unix 3 [ ] STREAM CONNECTED 13930 344/php
unix 3 [ ] STREAM CONNECTED 14763 503/php
unix 2 [ ] DGRAM 8576 160/systemd-udevd
unix 3 [ ] STREAM CONNECTED 11549 344/php
unix 3 [ ] STREAM CONNECTED 9763 220/sh
unix 3 [ ] STREAM CONNECTED 7971 225/dbus-daemon /run/dbus/system_bus_socket
unix 2 [ ] DGRAM 13422 558/dhcpcd
unix 3 [ ] STREAM CONNECTED 8936 265/systemd-resolve
unix 3 [ ] STREAM CONNECTED 8988 279/ntpd
unix 3 [ ] STREAM CONNECTED 14497 445/shairport
unix 3 [ ] STREAM CONNECTED 7887 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 7808 225/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15430 776/xbindkeys
unix 3 [ ] STREAM CONNECTED 13047 514/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 12136 272/redis-server 12 /tmp/redis.sock
unix 2 [ ] DGRAM 10199 279/ntpd
unix 3 [ ] STREAM CONNECTED 7886 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 14786 514/Xorg
unix 3 [ ] STREAM CONNECTED 13108 297/php
unix 2 [ ] DGRAM 13903 1/init
unix 3 [ ] STREAM CONNECTED 14560 452/bash
unix 3 [ ] STREAM CONNECTED 12054 445/shairport
unix 3 [ ] STREAM CONNECTED 7807 225/dbus-daemon
unix 3 [ ] STREAM CONNECTED 13861 514/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] DGRAM 8583 160/systemd-udevd
unix 2 [ ] DGRAM 9968 223/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 8749 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 11263 225/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 11963 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 8975 285/nginx: master p
unix 2 [ ] DGRAM 9283 133/systemd-journal
unix 3 [ ] STREAM CONNECTED 9077 297/php
unix 3 [ ] STREAM CONNECTED 13565 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 12787 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 10992 272/redis-server 12
unix 3 [ ] STREAM CONNECTED 9903 223/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 8987 279/ntpd
unix 3 [ ] STREAM CONNECTED 15086 272/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 15450 514/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 9097 503/php
unix 3 [ ] STREAM CONNECTED 7794 225/dbus-daemon
unix 3 [ ] STREAM CONNECTED 11013 285/nginx: master p
unix 3 [ ] STREAM CONNECTED 8527 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13928 344/php
unix 3 [ ] STREAM CONNECTED 9976 223/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 7739 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 9971 223/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 7806 225/dbus-daemon
unix 3 [ ] DGRAM 8584 160/systemd-udevd
unix 3 [ ] STREAM CONNECTED 7885 266/sshd
unix 3 [ ] STREAM CONNECTED 13061 514/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 12886 272/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 12794 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 15095 725/midori
unix 3 [ ] STREAM CONNECTED 11725 382/smbd
unix 3 [ ] STREAM CONNECTED 13580 496/php-fpm: master
unix 2 [ ] DGRAM 8930 265/systemd-resolve
unix 3 [ ] STREAM CONNECTED 9717 219/ifplugd
unix 3 [ ] STREAM CONNECTED 12092 225/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 8974 285/nginx: master p
unix 3 [ ] STREAM CONNECTED 7953 1/init /run/systemd/journal/stdout
unix 2 [ ] STREAM CONNECTED 13632 510/sudo
unix 3 [ ] STREAM CONNECTED 7745 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 15439 779/php
unix 3 [ ] STREAM CONNECTED 11384 272/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 7809 225/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13637 225/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13013 513/xinit
unix 2 [ ] DGRAM 13634 510/sudo
unix 3 [ ] STREAM CONNECTED 13332 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 11014 285/nginx: master p
unix 3 [ ] STREAM CONNECTED 9972 239/avahi-daemon: c
###### Network interfaces (ip addr) ######
1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: eth0: mtu 1500 qdisc fq_codel state UP group default qlen 4000
link/ether b8:27:eb:ad:0e:59 brd ff:ff:ff:ff:ff:ff
inet 192.168.2.26/24 brd 192.168.2.255 scope global eth0
3: wlan0: mtu 1500 qdisc fq_codel state DORMANT group default qlen 1000
link/ether b8:27:eb:f8:5b:0c brd ff:ff:ff:ff:ff:ff
###### Network interfaces (ifconfig) ######
eth0: flags=4163 mtu 1500
inet 192.168.2.26 netmask 255.255.255.0 broadcast 192.168.2.255
ether b8:27:eb:ad:0e:59 txqueuelen 4000 (Ethernet)
RX packets 165 bytes 33645 (32.8 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 163 bytes 84948 (82.9 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73 mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 0 (Local Loopback)
RX packets 4049 bytes 188698 (184.2 KiB)
TX packets 4049 bytes 188698 (184.2 KiB)
wlan0: flags=4099 mtu 1500
ether b8:27:eb:f8:5b:0c txqueuelen 1000 (Ethernet)
RX packets 11 bytes 3882 (3.7 KiB)
RX errors 0 dropped 11 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
###### Network netctl profiles (netctl list) ######
eth0
eth0 netctl status
● netctl@eth0.service - Networking for netctl profile eth0
Loaded: loaded (/usr/lib/systemd/system/netctl@.service; static; vendor preset: disabled)
Active: inactive (dead)
Docs: man:netctl.profile(5)
eth0 netctl profile
Description='eth0 connection'
Interface=eth0
ForceConnect=yes
SkipNoCarrier=yes
Connection=ethernet
IP=dhcp
###### Kernel status (dmesg) ######
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.20-1-ARCH (builduser@leming) (gcc version 5.3.0 (GCC) ) #1 SMP Sat Mar 19 20:07:23 MDT 2016
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x3a400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80b88cc0, node_mem_map b9bb4000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9380->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @bafac000 s21132 r8192 d23924 u53248
[ 0.000000] pcpu-alloc: s21132 r8192 d23924 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2709.boardrev=0xa02082 bcm2709.serial=0x7cad0e59 smsc95xx.macaddr=B8:27:EB:AD:0E:59 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rw rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 kgdboc=ttyS0,115200 elevator=noop ipv6.disable=1 quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 936208K/966656K available (7904K kernel code, 676K rwdata, 2840K rodata, 412K init, 780K bss, 22256K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80a86280 (10745 kB)
.init : 0x80a87000 - 0x80aee000 ( 412 kB)
.data : 0x80aee000 - 0x80b97048 ( 677 kB)
.bss : 0x80b9a000 - 0x80c5d33c ( 781 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000013] Switching to timer-based delay loop, resolution 52ns
[ 0.000133] Console: colour dummy device 80x30
[ 0.000219] console [tty1] enabled
[ 0.000237] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000247] pid_max: default: 32768 minimum: 301
[ 0.000414] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000420] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000928] Initializing cgroup subsys blkio
[ 0.000941] Initializing cgroup subsys memory
[ 0.000953] Initializing cgroup subsys devices
[ 0.000961] Initializing cgroup subsys freezer
[ 0.000970] Initializing cgroup subsys net_cls
[ 0.000983] Initializing cgroup subsys bfqio
[ 0.000992] Initializing cgroup subsys perf_event
[ 0.001000] Initializing cgroup subsys net_prio
[ 0.001029] CPU: Testing write buffer coherency: ok
[ 0.001340] CPU0: update cpu_capacity 1024
[ 0.001346] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001351] [bcm2709_smp_prepare_cpus] enter
[ 0.001416] Setting up static identity map for 0x8240 - 0x8274
[ 0.002301] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.002438] [bcm2709_secondary_init] enter cpu:1
[ 0.002465] CPU1: update cpu_capacity 1024
[ 0.002468] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.002676] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.002780] [bcm2709_secondary_init] enter cpu:2
[ 0.002790] CPU2: update cpu_capacity 1024
[ 0.002793] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.002966] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.003062] [bcm2709_secondary_init] enter cpu:3
[ 0.003072] CPU3: update cpu_capacity 1024
[ 0.003075] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.003105] Brought up 4 CPUs
[ 0.003115] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.003119] CPU: All CPU(s) started in HYP mode.
[ 0.003122] CPU: Virtualization extensions available.
[ 0.003480] devtmpfs: initialized
[ 0.011920] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.012039] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.012348] xor: measuring software checksum speed
[ 0.109915] arm4regs : 1845.600 MB/sec
[ 0.209944] 8regs : 1373.200 MB/sec
[ 0.309975] 32regs : 1324.000 MB/sec
[ 0.410004] neon : 2214.400 MB/sec
[ 0.410009] xor: using function: neon (2214.400 MB/sec)
[ 0.410065] pinctrl core: initialized pinctrl subsystem
[ 0.410325] NET: Registered protocol family 16
[ 0.413485] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.414068] bcm2709.uart_clock = 48000000
[ 0.415888] bcm2709: Mini UART enabled
[ 0.416120] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.416125] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.416192] Serial: AMBA PL011 UART driver
[ 0.416215] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.416288] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.630209] raid6: int32x1 gen() 209 MB/s
[ 0.800369] raid6: int32x1 xor() 182 MB/s
[ 0.970347] raid6: int32x2 gen() 307 MB/s
[ 1.140375] raid6: int32x2 xor() 210 MB/s
[ 1.310543] raid6: int32x4 gen() 326 MB/s
[ 1.480603] raid6: int32x4 xor() 241 MB/s
[ 1.650676] raid6: int32x8 gen() 333 MB/s
[ 1.820791] raid6: int32x8 xor() 227 MB/s
[ 1.990818] raid6: neonx1 gen() 718 MB/s
[ 2.160834] raid6: neonx2 gen() 1090 MB/s
[ 2.330885] raid6: neonx4 gen() 1294 MB/s
[ 2.500993] raid6: neonx8 gen() 1283 MB/s
[ 2.500997] raid6: using algorithm neonx4 gen() 1294 MB/s
[ 2.501001] raid6: using intx1 recovery algorithm
[ 2.501154] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[ 2.501168] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[ 2.501425] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 2.501431] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 2.501709] SCSI subsystem initialized
[ 2.501875] usbcore: registered new interface driver usbfs
[ 2.501915] usbcore: registered new interface driver hub
[ 2.501975] usbcore: registered new device driver usb
[ 2.502418] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-19 20:39
[ 2.528912] Switched to clocksource arch_sys_counter
[ 2.556233] FS-Cache: Loaded
[ 2.556368] CacheFiles: Loaded
[ 2.560279] NET: Registered protocol family 2
[ 2.560729] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 2.560786] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 2.560880] TCP: Hash tables configured (established 8192 bind 8192)
[ 2.560936] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 2.560959] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 2.561070] NET: Registered protocol family 1
[ 2.561229] RPC: Registered named UNIX socket transport module.
[ 2.561233] RPC: Registered udp transport module.
[ 2.561237] RPC: Registered tcp transport module.
[ 2.561240] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.561872] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 2.562967] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 2.569296] VFS: Disk quotas dquot_6.6.0
[ 2.569426] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.570556] FS-Cache: Netfs 'nfs' registered for caching
[ 2.570913] NFS: Registering the id_resolver key type
[ 2.570939] Key type id_resolver registered
[ 2.570943] Key type id_legacy registered
[ 2.570956] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.571298] JFS: nTxBlock = 7378, nTxLock = 59025
[ 2.575786] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 2.577830] aufs 4.1-20160301
[ 2.578726] async_tx: api initialized (async)
[ 2.578777] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 2.578841] io scheduler noop registered (default)
[ 2.578851] io scheduler deadline registered
[ 2.578876] io scheduler cfq registered
[ 2.579035] io scheduler bfq registered
[ 2.579039] BFQ I/O-scheduler: v7r8
[ 2.580132] BCM2708FB: allocated DMA memory fa800000
[ 2.580145] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 2.596095] Console: switching to colour frame buffer device 228x61
[ 2.603936] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 2.604966] console [ttyS0] disabled
[ 2.605002] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
[ 2.605300] console [ttyS0] enabled
[ 2.605507] KGDB: Registered I/O driver kgdboc
[ 2.659093] vc-cma: Videocore CMA driver
[ 2.659098] vc-cma: vc_cma_base = 0x00000000
[ 2.659102] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 2.659106] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 2.659180] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 2.664185] brd: module loaded
[ 2.667306] loop: module loaded
[ 2.667805] vchiq: vchiq_init_state: slot_zero = 0xba880000, is_master = 0
[ 2.668834] Loading iSCSI transport class v2.0-870.
[ 2.669276] usbcore: registered new interface driver ax88179_178a
[ 2.669329] usbcore: registered new interface driver smsc95xx
[ 2.669396] usbcore: registered new interface driver cdc_ncm
[ 2.669406] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.869538] Core Release: 2.80a
[ 2.869545] Setting default values for core params
[ 2.869561] Finished setting default values for core params
[ 3.069738] Using Buffer DMA mode
[ 3.069743] Periodic Transfer Interrupt Enhancement - disabled
[ 3.069746] Multiprocessor Interrupt Enhancement - disabled
[ 3.069751] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.069757] Dedicated Tx FIFOs mode
[ 3.069912] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xba814000 dma = 0xfa814000 len=9024
[ 3.069927] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
[ 3.069935] dwc_otg: Microframe scheduler enabled
[ 3.069956] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x805cb7e8
[ 3.069962] WARN::hcd_init_fiq:413: FIQ ASM at 0x805cbb30 length 36
[ 3.069968] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbbcee000
[ 3.069984] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.070004] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.070019] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 3.070054] Init: Port Power? op_state=1
[ 3.070057] Init: Power Port (0)
[ 3.070153] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.070159] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.070166] usb usb1: Product: DWC OTG Controller
[ 3.070171] usb usb1: Manufacturer: Linux 4.1.20-1-ARCH dwc_otg_hcd
[ 3.070176] usb usb1: SerialNumber: 3f980000.usb
[ 3.070518] hub 1-0:1.0: USB hub found
[ 3.070537] hub 1-0:1.0: 1 port detected
[ 3.070699] dwc_otg: FIQ enabled
[ 3.070703] dwc_otg: NAK holdoff enabled
[ 3.070706] dwc_otg: FIQ split-transaction FSM enabled
[ 3.070721] Module dwc_common_port init
[ 3.070828] usbcore: registered new interface driver usb-storage
[ 3.070862] usbcore: registered new interface driver ums-alauda
[ 3.070895] usbcore: registered new interface driver ums-cypress
[ 3.070923] usbcore: registered new interface driver ums-datafab
[ 3.070951] usbcore: registered new interface driver ums_eneub6250
[ 3.070979] usbcore: registered new interface driver ums-freecom
[ 3.071011] usbcore: registered new interface driver ums-isd200
[ 3.071040] usbcore: registered new interface driver ums-jumpshot
[ 3.071068] usbcore: registered new interface driver ums-karma
[ 3.071096] usbcore: registered new interface driver ums-onetouch
[ 3.071135] usbcore: registered new interface driver ums-realtek
[ 3.071165] usbcore: registered new interface driver ums-sddr09
[ 3.071195] usbcore: registered new interface driver ums-sddr55
[ 3.071223] usbcore: registered new interface driver ums-usbat
[ 3.071319] mousedev: PS/2 mouse device common for all mice
[ 3.071624] md: linear personality registered for level -1
[ 3.071634] md: raid0 personality registered for level 0
[ 3.071643] md: raid1 personality registered for level 1
[ 3.071651] md: raid10 personality registered for level 10
[ 3.071741] md: raid6 personality registered for level 6
[ 3.071745] md: raid5 personality registered for level 5
[ 3.071749] md: raid4 personality registered for level 4
[ 3.071758] md: multipath personality registered for level -4
[ 3.071767] md: faulty personality registered for level -5
[ 3.071927] device-mapper: uevent: version 1.0.3
[ 3.072121] device-mapper: ioctl: 4.31.0-ioctl (2015-3-12) initialised: dm-devel@redhat.com
[ 3.072398] device-mapper: multipath: version 1.9.0 loaded
[ 3.072409] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 3.072419] device-mapper: multipath queue-length: version 0.1.0 loaded
[ 3.072428] device-mapper: multipath service-time: version 0.2.0 loaded
[ 3.072448] device-mapper: raid: Loading target version 1.6.0
[ 3.072557] bcm2835-cpufreq: min=1200000 max=1200000
[ 3.072736] sdhci: Secure Digital Host Controller Interface driver
[ 3.072740] sdhci: Copyright(c) Pierre Ossman
[ 3.072879] sdhost: log_buf @ ba813000 (fa813000)
[ 3.148921] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.150934] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 3.150940] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 3.188960] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.189119] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.189184] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.189364] usbcore: registered new interface driver usbhid
[ 3.189368] usbhid: USB HID core driver
[ 3.189565] Initializing XFRM netlink socket
[ 3.189582] NET: Registered protocol family 17
[ 3.189649] Key type dns_resolver registered
[ 3.190015] Registering SWP/SWPB emulation handler
[ 3.190316] registered taskstats version 1
[ 3.191754] Btrfs loaded
[ 3.192394] Key type encrypted registered
[ 3.192434] vc-sm: Videocore shared memory driver
[ 3.192440] [vc_sm_connected_init]: start
[ 3.192672] [vc_sm_connected_init]: end - returning 0
[ 3.193752] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 3.194270] md: Waiting for all devices to be available before autodetect
[ 3.194275] md: If you don't use raid, use raid=noautodetect
[ 3.194663] md: Autodetecting RAID arrays.
[ 3.194668] md: Scanned 0 and added 0 devices.
[ 3.194671] md: autorun ...
[ 3.194674] md: ... autorun DONE.
[ 3.194749] Waiting for root device /dev/mmcblk0p2...
[ 3.205980] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.207849] mmc0: new high speed SDHC card at address 0007
[ 3.208045] mmcblk0: mmc0:0007 SL16G 14.5 GiB
[ 3.209019] mmcblk0: p1 p2
[ 3.228851] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.230342] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.231829] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.234499] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.268966] Indeed it is in host mode hprt0 = 00021501
[ 3.319875] mmc1: new high speed SDIO card at address 0001
[ 3.448936] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.449008] Indeed it is in host mode hprt0 = 00001101
[ 3.649040] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 3.649047] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.649418] hub 1-1:1.0: USB hub found
[ 3.649460] hub 1-1:1.0: 5 ports detected
[ 3.928922] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.029034] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 4.029041] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.031318] smsc95xx v1.0.4
[ 4.090370] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ad:0e:59
[ 9.424569] EXT4-fs (mmcblk0p2): recovery complete
[ 10.397961] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 10.397991] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 10.407171] devtmpfs: mounted
[ 10.407504] Freeing unused kernel memory: 412K (80a87000 - 80aee000)
[ 10.740425] systemd[1]: System time before build time, advancing clock.
[ 10.823634] IPv6: Loaded, but administratively disabled, reboot required to enable
[ 10.839001] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.842640] random: systemd urandom read with 81 bits of entropy available
[ 10.851594] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 10.851868] systemd[1]: Detected architecture arm.
[ 10.852757] systemd[1]: Set hostname to .
[ 11.308487] systemd[1]: Listening on udev Kernel Socket.
[ 11.309378] systemd[1]: Created slice System Slice.
[ 11.309688] systemd[1]: Created slice system-netctl\x2difplugd.slice.
[ 11.309971] systemd[1]: Created slice system-getty.slice.
[ 11.310079] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 11.310192] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.310455] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 11.310589] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 11.310635] systemd[1]: Reached target Slices.
[ 11.310690] systemd[1]: Reached target Remote File Systems.
[ 11.310808] systemd[1]: Listening on Journal Socket.
[ 11.330927] systemd[1]: Starting RuneAudio shutdown script...
[ 11.335931] systemd[1]: Starting Load Kernel Modules...
[ 11.337723] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.356178] systemd[1]: Mounting Temporary Directory...
[ 11.357874] systemd[1]: Mounting Debug File System...
[ 11.359611] systemd[1]: Starting Setup Virtual Console...
[ 11.361364] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 11.361588] systemd[1]: Listening on udev Control Socket.
[ 11.361685] systemd[1]: Reached target Encrypted Volumes.
[ 11.407688] systemd[1]: Starting Journal Service...
[ 11.408363] systemd[1]: Created slice system-netctl\x2dauto.slice.
[ 11.408448] systemd[1]: Reached target System Time Synchronized.
[ 11.417061] systemd[1]: Listening on Process Core Dump Socket.
[ 11.417200] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 11.417633] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.451254] systemd[1]: Reached target Swap.
[ 11.452830] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.453061] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
by Frost_dk » 05 Aug 2017, 10:10
by hondagx35 » 05 Aug 2017, 22:01
I connect to runeaudio.local
by Frost_dk » 05 Aug 2017, 22:07
hondagx35 wrote:Hi frost_dk,I connect to runeaudio.local
Please try to connect via the IP address instead.
by hondagx35 » 05 Aug 2017, 22:11
by Frost_dk » 05 Aug 2017, 22:16
by hondagx35 » 05 Aug 2017, 22:34
/dev/root 1.9G 1.9G 0 100% /
by Frost_dk » 05 Aug 2017, 22:40
by andfor » 21 Aug 2017, 21:05
support RuneAudio
