eea123 wrote:I'm still betting you could have manually edited the config file in PuTTY and changed the card type. The default in v0.4 was this, I changed it to dacplus and mine took right off.
# Uncomment one of these lines to enable an audio interface
dtoverlay=hifiberry-dac
#dtoverlay=hifiberry-dacplus
#dtoverlay=hifiberry-digi
#dtoverlay=hifiberry-amp
#dtoverlay=iqaudio-dac
#dtoverlay=iqaudio-dacplus
foxint wrote:I have no idea about changing the code. It scares me going into the code. If I do I will probably get chastised by someone when I mess it up. So safer it I do not.
foxint > What eea123 is refering to is NOT editing code, it IS editing a simple TEXT file..... repeat: editing a SIMPLE text file. Nothing more than that, and really... think about this: editing this text file is simple, AND it may BE the answer to your issue!!!
It seems to me your NAS/network problem has been going on for over a year now, and you have started THREE threads about the same subject.
It seems to me your HiFiBerry DAC + Pro XLR problem has been going on for over month now, and you have started TWO threads about the same subject.
19 Feb 2018, 17:49 : Lost Pi on Network
07 Dec 2018, 16:39: Set Up for HiFiBerry DAC + Pro XLR
27 Dec 2018, 07:15: Cannnot Load HiFiBerry DAC Plus Pro XLR Module
02 Jan 2019, 10:01: RuneAudio Temporarily Unavailable NOW regularly
08 Jan 2019, 18:49: Cannot mount NAS
Suggestion: Solve ONE probem at a time, and do not move onto the next problem UNTIL after it has been solved. Open/start ONE thread about ONE problem and see it through to the end, ie: until it is fixed. Do not move on to the next problem. You are making it more complex than it is. Children, school age children, are using the Raspberry Pi for software coding. Surely if the Raspberry Pi is too complex then move on and buy a complete product (ask for suggestions).
