Page 1 of 1
Spotify - how to install
PostPosted: 06 Jan 2019, 21:08
by stefan2140
I run runeaudio on a raspberry pi 3. No DAC or so attached for the moment.
I want to integrate spotify in my sources.
In the settings page, I try to set the 'on' button in the spotify section.
It isn't the same colour blue as the selected buttons in the other sections.
I have set my spotify- username and password. I'm sure it are the right ones, as I'm sure I have spotify premium.
In the sources section, I can click the spotify-section.
If I click the library button I get a screen with 'favorites', but I don't see any spotify playlists.
So, I'm missing some point...
Re: Spotify - how to install
PostPosted: 06 Jan 2019, 22:10
by janui
Hi stefan2140,
stefan2140 wrote:I want to integrate spotify in my sources.
Sorry, it wont work any more. Spotify changed their software and the RuneAudio interfaces to it no longer work. For details, see here: post25345.html?hilit=spotify%20janui#p25345
There are instructions for installing Spotify Connect on the forum, see here: spotify-connect-on-runeaudio-t6315.html#p25010
As an alternative, if you access Spotify using your smartphone/tablet/laptop you can stream music to RuneAudio using Airplay (for Apple) or UPnP / DLNA (for Android/Microsoft).
PostPosted: 12 Sep 2019, 16:18
by pez
Hey janui,
could you please give me some information about how to stream music to RuneAudio using my windows PC (uPnp/DLNA)?
Cheers,
pez
PostPosted: 12 Sep 2019, 21:13
by janui
Hi pez,
pez wrote:...could you please give me some information about how to stream music to RuneAudio using my windows PC (uPnp/DLNA)?...
You should really start a new thread with this question, but never mind...
I only use uPnp/DLNA occasionally, streaming from a PC using Window Media Player (WMP), I have not tested it with other products. Here is the setup:
    - The current RuneAudio playback source should me MPD
    - Switch ‘random play’ off in the MPD UI
    - Switch 'uPnp/DLNA' on in the Settings UI
    - I recommend setting 'UPnP / DLNA is MPD queue owner' on
    - RuneAudio then appears in the music player pull down in WMP, select it
    - The WMP queue will then play via RuneAudio after clicking play
In RuneAudio the contents of the queue will be cleared and the currently playing track appears in the queue. Metadata and album art are displayed in the main RuneAudio playback UI if these available in the source.
Look here for some more info about upmpdcli, which we use to play UPnP/DLNA streams: https://www.lesbonscomptes.com/upmpdcli/index.html
And here for client applications/control points: https://www.lesbonscomptes.com/upmpdcli ... oints.html
PostPosted: 26 May 2021, 09:17
by IsaacFloyd
You can install Spotify for free here https://gamestoremobi.com/spotify-premium.html
PostPosted: 04 Apr 2024, 04:53
by JudithRogers
Spotify is a great music listening application. I chose gameyolo to download the great apk file version of this application
