Page 1 of 1
Static on 24bit
PostPosted: 14 Nov 2018, 00:49
by thedman!
Hi all,
I'm sure I've seen this before, but have searched everywhere to no avail.
I/m getting static when playing 24bit audio.
RPi 3b+>Kali>Allo Piano 2.0, latest version of Rune.
All is fine on 16 bit, but pure static - no music on 24 bit.
https://pastebin.com/jsawRUL2
Thanks in advance,
Dave.
Re: Static on 24bit
PostPosted: 14 Nov 2018, 19:14
by thedman!
Hmmm. Its not just 24 bit. I'll investigate further... Hold your horses.
Re: Static on 24bit
PostPosted: 14 Nov 2018, 23:11
by janui
Hi thedman!,
thedman! wrote:I'm getting static when playing 24bit audio.
There is a documented bug concerning the Allo Piano 2.1 driver when used together with the latest kernel versions. A workaround has been implemented for 'RPi x>Kali>Allo Piano 2.1'. The same bug could also be present in the Allo Piano 2.0 driver. You could try selecting the 'Allo Piano 2.1 DAC Plus with Kali Reclocker' I²S kernel module in the Settings UI.
Re: Static on 24bit
PostPosted: 01 Dec 2018, 00:31
by Stymieddd
Could the driver for Piano 2.0 be extracted from Volum*** and place in Rune?
Re: Static on 24bit
PostPosted: 01 Dec 2018, 00:51
by thedman!
I think I fixed this... But then formatted my sd card before I could fully check...
There some advice on this forum you can use to fix it, but again, I can't check right now...
You need to force sox to resample to 32bit, I think.
Very approximately edit mpd find your device, and add a newline similar to
Format 192000:32:* or 192000:32:2
I post something soonish, maybe tomorrow, when I fix it.
Re: Static on 24bit
PostPosted: 01 Dec 2018, 19:44
by thedman!
see piano-not-2-1-version-driver-not-working-t6653.html
The fix is working for me now...
