Re: RuneAudio 0.5-beta for all Raspberry Pi models
Posted: 06 Nov 2018, 19:03
Unfortunately , it did not work for me after the gitpull / mount deletion/reinstate
cheers
Nic
cheers
Nic
Embedded hi-fi music player
https://www.runeaudio.com/forum/
https://www.runeaudio.com/forum/runeaudio-0-5-beta-for-all-raspberry-pi-models-t6532-180.html
nic wrote:Unfortunately , it did not work for me after the gitpull / mount deletion/reinstate
cheers
Nic
nic wrote:Mount flags set to
cache=none,noserverino,ro,vers=1.0
...worked . I tried this before the gitpull but no joy but adfter the gitpull , works fine
cheers
Nic
nic wrote:It's all good , Janui has been really helpful . I say kudos ! I'm really enjoying the new build .
cheers
Nic
Could you double check that the files have album art. This part of the software has not changed between 0.4b and 0.5b. If you confirm that it is a problem, please provide all the information which you can.Vhond wrote: Album Art not shown in the playback screen (using Flac files)
At this moment gitpull has only been used to update the UI, with the exception of installing lirc on the Pi1 image.Vhond wrote:the git pull function in the dev section (only the UI or also kernel related issues which have been updated in a newer 0.5 beta release??)
