Page 1 of 2
How to install upmpdcli on RuneAudio for Tidal streaming?
PostPosted: 18 Jul 2018, 03:55
by tml3nr
After compare sound quality between upmpdcli and bubbleupnp server for Tidal streaming. I prefer upmpdcli.
i've just tested upmpdcli on Raspbian Stretch. It's works perfectly, but i can't install on RuneAudio 0.4. i've tried many time but unsuccessfully.
Help me please. i don't know what to do anymore.
https://www.lesbonscomptes.com/upmpdcli ... anual.html
PS: My setup Rune 0.4-beta_20170229 / RPi 2 / Boss Dac
Debug data:
https://pastebin.com/Avad5wQi
Re: How to install upmpdcli on RuneAudio for Tidal streaming
PostPosted: 18 Jul 2018, 08:37
by janui
Hi tml3nr,
tml3nr wrote:i've just tested upmpdcli on Raspbian Stretch. It's works perfectly, but i can't install on RuneAudio 0.4. i've tried many time but unsuccessfully.
upmpdcli is already installed. Switch it on in the Settings menu.
PostPosted: 18 Jul 2018, 15:14
by tml3nr
janui wrote:Hi tml3nr,
Thank you for your reply. upmpdcli preinstall on Rune 0.4 is old version, it's not support Tidal streaming.
In upmpdcli new version. It's contains tidal plugins.
Picture below i capture on archphile 0.99.73. Tidal streaming perfectly:
Many thanks for your help!
PostPosted: 23 Jul 2018, 09:16
by janui
Hi tml3nr,
To upgrade upmpdcli to v1.2.15…
First upgrade some packages:
pacman -Sy
pacman -S libmicrohttpd libjsoncpp gcc gcc-libs
Download these two Rune packages:
http://www.mediafire.com/file/3wp0qaqi5 ... ar.xz/file sha-256:
0FDC6AF44C90BF66311542C6870711093C508BE28493570FED1E949DAD6678ED
http://www.mediafire.com/file/h566dk94a ... ar.xz/file sha-256:
5FA85F5E0EB78DB24E4C5BA583301E0F74571C63C625AE1E7AB56942EC47B8A9
Install them, with:
pacman -U upmpdcli-rune-1.2.15-3-armv7h.pkg.tar.xz
and:
pacman -U libupnpp-rune-20180125-1-armv7h.pkg.tar.xz
Then remove gcc, with:
pacman -Rs gcc
Check that Rune still works, run:
php -f /srv/http/db/redis_datastore_setup check
php -f /srv/http/command/debug_collector
php -f /srv/http/command/refresh_nics
There should be no errors from these scripts. This is not a full test but gives a good indication that all is OK.
Restart upmpdcli with:
systemctl daemon-reload
systemctl start upmpdcli
systemctl status upmpdcli
You should see that upmpdcli is running.
Sorry, I can’t help with configuring upmpdcli for Tidal. Please share any additional information.
PostPosted: 24 Jul 2018, 01:38
by tml3nr
pacman -Sy
pacman -S libmicrohttpd jsoncpp gcc gcc-libs
Install them, with:
and:
pacman -Rs gcc
Many thanks to janui! Follow your instructions. I just tested:
root@runeaudio(rw):~# pacman -Sy
:: Synchronizing package databases...
 core                                   214.0 KiB   690K/s 00:00 [###################################] 100%
 extra                                    2.2 MiB  2.91M/s 00:01 [###################################] 100%
 community                                4.7 MiB   601K/s 00:08 [###################################] 100%
 alarm                                  111.2 KiB   505K/s 00:00 [###################################] 100%
 aur                                      6.1 KiB  0.00B/s 00:00 [###################################] 100%
root@runeaudio(rw):~# pacman -S libmicrohttpd
resolving dependencies...
looking for conflicting packages...
Packages (1) libmicrohttpd-0.9.59-1
Total Download Size:   0.17 MiB
Total Installed Size:  0.35 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 libmicrohttpd-0.9.59-1-armv7h          173.9 KiB  1242K/s 00:00 [###################################] 100%
(1/1) checking keys in keyring                                   [###################################] 100%
(1/1) checking package integrity                                 [###################################] 100%
(1/1) loading package files                                      [###################################] 100%
(1/1) checking for file conflicts                                [###################################] 100%
(1/1) checking available disk space                              [###################################] 100%
:: Processing package changes...
(1/1) installing libmicrohttpd                                   [###################################] 100%
root@runeaudio(rw):~# pacman -S jsoncpp
Packages (1) jsoncpp-1.8.4-2
Total Download Size:   0.09 MiB
Total Installed Size:  0.54 MiB
Net Upgrade Size:      0.27 MiB
 jsoncpp-1.8.4-2-armv7h                  95.3 KiB   596K/s 00:00 [###################################] 100%
(1/1) upgrading jsoncpp                                          [###################################] 100%
New optional dependencies for jsoncpp
    jsoncpp-doc: documentation
root@runeaudio(rw):~# pacman -S gcc
Packages (5) binutils-2.30-5  gcc-libs-8.1.1+20180531-1  glibc-2.27-3  linux-api-headers-4.16.1-1
             gcc-8.1.1+20180531-1
Total Download Size:    53.72 MiB
Total Installed Size:  237.00 MiB
Net Upgrade Size:      141.17 MiB
 linux-api-headers-4.16.1-1-any         940.9 KiB  3.83M/s 00:00 [###################################] 100%
 glibc-2.27-3-armv7h                      8.2 MiB   636K/s 00:13 [###################################] 100%
 gcc-libs-8.1.1+20180531-1-armv7h        16.2 MiB  1401K/s 00:12 [###################################] 100%
 binutils-2.30-5-armv7h                   4.6 MiB   938K/s 00:05 [###################################] 100%
 gcc-8.1.1+20180531-1-armv7h             23.9 MiB  1986K/s 00:12 [###################################] 100%
(5/5) checking keys in keyring                                   [###################################] 100%
(5/5) checking package integrity                                 [###################################] 100%
(5/5) loading package files                                      [###################################] 100%
(5/5) checking for file conflicts                                [###################################] 100%
(5/5) checking available disk space                              [###################################] 100%
warning: could not get file information for var/db/Makefile
(1/5) upgrading linux-api-headers                                [###################################] 100%
(2/5) upgrading glibc                                            [###################################] 100%
warning: /etc/locale.gen installed as /etc/locale.gen.pacnew
warning: directory permissions differ on /usr/lib/systemd/system/
filesystem: 644  package: 755
Generating locales...
  de_DE.UTF-8... done
  en_GB.UTF-8... done
  en_US.UTF-8... done
Generation complete.
New optional dependencies for glibc
    gd: for memusagestat
(3/5) upgrading gcc-libs                                         [###################################] 100%
(4/5) installing binutils                                        [###################################] 100%
(5/5) installing gcc                                             [###################################] 100%
root@runeaudio(rw):~# pacman -S gcc-libs
warning: gcc-libs-8.1.1+20180531-1 is up to date -- reinstalling
Packages (1) gcc-libs-8.1.1+20180531-1
Total Installed Size:  76.08 MiB
Net Upgrade Size:       0.00 MiB
(1/1) reinstalling gcc-libs                                      [###################################] 100%
root@runeaudio(rw):~# pacman -U upmpdcli-rune-1.2.15-3-armv7h.pkg.tar.xz
loading packages...
warning: upmpdcli-rune-1.2.15-3 is up to date -- reinstalling
Packages (1) upmpdcli-rune-1.2.15-3
Total Installed Size:  1.46 MiB
(1/1) checking keys in keyring                                                          [###################################################] 100%
(1/1) checking package integrity                                                        [###################################################] 100%
(1/1) loading package files                                                             [###################################################] 100%
(1/1) checking for file conflicts                                                       [###################################################] 100%
(1/1) checking available disk space                                                     [###################################################] 100%
(1/1) reinstalling upmpdcli-rune                                                        [###################################################] 100%
root@runeaudio(rw):~# pacman -U libupnpp-rune-20180125-1-armv7h.pkg.tar.xz
loading packages...
Packages (1) libupnpp-rune-20180125-1
Total Installed Size:  0.84 MiB
Net Upgrade Size:      0.15 MiB
warning: could not get file information for usr/include/libupnpp/base64.hxx
warning: could not get file information for usr/include/libupnpp/control/avtransport.hxx
warning: could not get file information for usr/include/libupnpp/control/cdircontent.hxx
warning: could not get file information for usr/include/libupnpp/control/cdirectory.hxx
warning: could not get file information for usr/include/libupnpp/control/description.hxx
warning: could not get file information for usr/include/libupnpp/control/device.hxx
warning: could not get file information for usr/include/libupnpp/control/discovery.hxx
warning: could not get file information for usr/include/libupnpp/control/mediarenderer.hxx
warning: could not get file information for usr/include/libupnpp/control/mediaserver.hxx
warning: could not get file information for usr/include/libupnpp/control/ohplaylist.hxx
warning: could not get file information for usr/include/libupnpp/control/ohproduct.hxx
warning: could not get file information for usr/include/libupnpp/control/renderingcontrol.hxx
warning: could not get file information for usr/include/libupnpp/control/service.hxx
warning: could not get file information for usr/include/libupnpp/device/device.hxx
warning: could not get file information for usr/include/libupnpp/log.hxx
warning: could not get file information for usr/include/libupnpp/ptmutex.hxx
warning: could not get file information for usr/include/libupnpp/soaphelp.hxx
warning: could not get file information for usr/include/libupnpp/upnpavutils.hxx
warning: could not get file information for usr/include/libupnpp/upnpplib.hxx
warning: could not get file information for usr/include/libupnpp/upnpputils.hxx
warning: could not get file information for usr/lib/libupnpp.so
(1/1) upgrading libupnpp-rune                                    [###################################] 100%
root@runeaudio(rw):~# php -f /srv/http/db/redis_datastore_setup check
root@runeaudio(rw):~# php -f /srv/http/command/debug_collector
root@runeaudio(rw):~# php -f /srv/http/command/refresh_nics
root@runeaudio(rw):~# systemctl daemon-reload
root@runeaudio(rw):~# systemctl start upmpdcli
root@runeaudio(rw):~# systemctl status upmpdcli
● upmpdcli.service - Upmpdcli UPnP/dlna receiver
   Loaded: loaded (/usr/lib/systemd/system/upmpdcli.service; disabled; vendor preset: disabled)
   Active: active (running) since Mon 2016-02-22 21:42:34 ICT; 2 years 4 months ago
 Main PID: 961 (upmpdcli)
   CGroup: /system.slice/upmpdcli.service
           └─961 /usr/bin/upmpdcli -d /var/log/runeaudio/upmpdcli.log -l 6 -f RuneAudio (UPnP)
Feb 22 21:42:34 runeaudio systemd[1]: Started Upmpdcli UPnP/dlna receiver.
Jul 23 21:00:39 runeaudio systemd[1]: Started Upmpdcli UPnP/dlna receiver.
root@runeaudio(rw):~# /usr/bin/upmpdcli -v
Upmpdcli 1.2.15 libupnpp 0.16.1
At this point Rune UPnP renderer work fine. But mediaserver for Tidal does not appear.
i add to /etc/upmpdcli.conf:
tidaluser = my_email
tidalpass = my_password
tidalquality = lossless
ohproductroom = RuneAudio-room
After restart upmpdcli service. Rune mediaserver appear. But when access to Tidal service. It's error, may be some Tidal API is not correct:
   Active: active (running) since Tue 2018-07-24 06:08:34 ICT; 20min ago
 Main PID: 1251 (upmpdcli)
    Tasks: 16 (limit: 512)
           ├─1251 /usr/bin/upmpdcli -c /etc/upmpdcli.conf
           └─1262 /usr/bin/upmpdcli -m 2 -c /etc/upmpdcli.conf
Jul 24 06:09:20 runeaudio upmpdcli[1251]:     import tidalapi
Jul 24 06:09:20 runeaudio upmpdcli[1251]:   File "/usr/share/upmpdcli/cdplugins/tidal/tidalapi/__init__.py", line 26, in <module>
Jul 24 06:09:20 runeaudio upmpdcli[1251]:     import requests
Jul 24 06:09:20 runeaudio upmpdcli[1251]: ModuleNotFoundError: No module named 'requests'
Jul 24 06:09:21 runeaudio upmpdcli[1251]: Traceback (most recent call last):
Jul 24 06:09:21 runeaudio upmpdcli[1251]:   File "/usr/share/upmpdcli/cdplugins/tidal/tidal-app.py", line 33, in <module>
Jul 24 06:09:21 runeaudio upmpdcli[1251]:     import tidalapi
Jul 24 06:09:21 runeaudio upmpdcli[1251]:   File "/usr/share/upmpdcli/cdplugins/tidal/tidalapi/__init__.py", line 26, in <module>
Jul 24 06:09:21 runeaudio upmpdcli[1251]:     import requests
Jul 24 06:09:21 runeaudio upmpdcli[1251]: ModuleNotFoundError: No module named 'requests'
Even without mediaserver. Updating upmpdcli on Rune is a miracle.
I hope there will be a new Rune version in the near future, and Tidal can work on upmpdcli.
Many thanks again!
PostPosted: 28 Sep 2018, 10:28
by vlaca
Hi!
I tried the Tidal on new runeaudio 05b, but not working.
(Maybe it has newer upmpdcli, just edited the config and reboot. The runeaudio-mediaserver running, and appear in Kazoo and Lumin, but there is still communication error message. On Moode/Volumio worked similar method.)
Somebody know the solution for Tidal streaming in Runeaudio?
Thank you!
(V)Laca
PostPosted: 28 Sep 2018, 13:44
by tml3nr
vlaca wrote:Hi!
Thank you!
(V)Laca
Unfortunately, version 0.5b still does not support upmpdcli Tidal pluggin.
By now the best way is enable Rune UPnP renderer. And play Tidal from an app on mobile device.
On IOS: AK Connect, MConnect...
On Android: BubbleUPnP, MConnect, AK Connect...
PostPosted: 28 Sep 2018, 18:47
by vlaca
Yeah, its working fine! :D
Thank you so mutch!
Vlaca
PostPosted: 17 Jan 2019, 13:31
by advr61
Unfortunately the pacman -Rs gcc command gives an error.
checking dependencies...
error: failed to prepare transaction (could not satisfy dependencies)
:: vala: removing gcc breaks dependency 'gcc'
anybody a direction to find the cause?
using the latest Runeaudio
PostPosted: 17 Jan 2019, 17:56
by janui
Hi advr61,
advr61 wrote:checking dependencies...
Seems that the vala package needs gcc to be installed.
You could try this:
pacman -Rs gcc vala
This will try to remove vala and gcc at the same time. It's possible that other dependencies will prevent this from working.
You can use this command to determine the dependencies of an installed package:
pactree <package_name>
If all else fails just leave gcc installed, its not really good practice, but should not cause problems. However, gcc does use a lot of disk space, if this is a problem expand the Linux partition.
