Page 1 of 52
PostPosted: 27 Feb 2017, 14:00
by hondagx35
Hi all,
a new image (Raspberry Pi2/3) is available for testing.
You can download it from my Google Drive.
What is new, has changed?
- If a WiFi device is available and no IP is assigned RuneAudio starts an AccessPoint.
SSID: RuneAudioAP
Passphrase: RuneAudio
IP: 192.168.5.1
- No need to edit config.txt, I2S DAC can be enabled from UI.
- password protection
The UI can be password protected (default "rune")
- screensaver mode for local and remote browser
- Artist and Lyric info
- randomly add songs from a playlist to the end of the current playlist
- Spotify only visible when enabled + browsing by Composer
- boot screen for local display (optimized for 7" TFT)
The pictures are located in "/usr/share/bootsplash"
- image can be made Read-Only (sorry not possible at the moment, because aufs is not enabled in the kernel)
Please contact me if you like to test this feature
- RaspiBackup installed and configured (but not available via UI yet)
- support for all new ALLO products
ALLO Piano 2.0 syncronized volumes (digital & subwoofer) when hardware volume is enabled.
- alsamixer now can be accessed via UI
Does not look good but sometimes very handy
http://yourIP:8080
- bugfixes and other small changes
I hope you like it ;)
Please feel free to post your comments / bug reports here.
PostPosted: 27 Feb 2017, 14:25
by ianhaynes
It's great to see this new release. I'd like to test the 'read only' feature please.
Thank you again for all the work the team put into it.
Ian
PostPosted: 27 Feb 2017, 15:06
by Stephane
I have just installed it. I had to configure my touchscreen by hand (Waveshare 800x480) because the resolution is not automatically set.
Can I save the configuration from the previous version and restore it to the new one? I have several webradios that I would not like to enter by hand again! :)
I will test it more this evening at home and report.
PostPosted: 27 Feb 2017, 15:53
by ianhaynes
All set up and working, once I remembered to reboot having set the DAC type :)
The WebRadio sorted alphabetically and not returning to the main library screen when you've added a station is excellent, thank you.
Three comments so far:
The words 'Library', 'Playback' and 'Queue' and their respective icons are all bottom-aligned. I'm sure they used to be vertically centered.
I've read elsewhere that the recent versions of MPD can play .M3U8 files natively (as used by the BBC now for their highest-res feeds). It would be great to have this in Rune. (rather than have to use MinimServer).
As noted by Stephane, it would be good to be able to save a list of Radio stations and bring them back into a new Rune installation.
Ian
PS: The artist and song information is excellent too.
PostPosted: 27 Feb 2017, 16:18
by Yatsushiro
This is not fair, I'm stuck at work... :evil:
Have you incorporated the 'audio' 384kHz advanced kernel?
PostPosted: 27 Feb 2017, 16:46
by Stephane
The local screensaver does not seem to work. I changed the value to 5 (minutes?) and nothing happens.
I have a Waveshare 7" HDMI and USB touchscreen (800x480) connected.
PostPosted: 27 Feb 2017, 21:15
by hondagx35
Hi Stephane,
Stephane wrote:Can I save the configuration from the previous version and restore it to the new one? I have several webradios that I would not like to enter by hand again! :)
Sorry, save and restore is not possible.
You can try this script from user "xan".
PostPosted: 27 Feb 2017, 23:04
by hondagx35
Hi Ian,
Thank you for pointing this out, this will be fixed with official release
The version used in this image should be able to use m3u8 but it is not compiled in.
I will try to get it in with the official release.
PostPosted: 27 Feb 2017, 23:06
by hondagx35
Hi Yatsushiro,
No, not yet.
PostPosted: 27 Feb 2017, 23:08
by hondagx35
Hi Stephane,
It is in seconds and only gets activated while playing and not on the settings screens.
