Page 61 of 65
PostPosted: 25 May 2019, 20:47
by R101
rern wrote:
R101 wrote:This update leaves most of the icons as just a font code in my 0.4b.
There is no metadata editing option in the menus. Is this because I do not display any cover art?
Try clear browser cache.
RuneUIe Metadata Tag Editor addon must be installed to show Tags menu. (10+ minutes)
Thanks rern,
The icons look to be browser dependent. They are missing in both my Android and Pale Moon browser, but work in Firefox 68. Uninstalling UIe restores the icons.
I tried the Tag Editor in 0.5 and it works fine. I am having so many problems with 0.4b now that I have reverted to using an old backup.
Is there any way to update MPD in 0.5 the same way as the 0.4b addon did? The addon's changes to ffmpeg fixed the m3u8 streaming, which is the only reason I am still using 0.4b.
"Star" Image Issue
PostPosted: 26 May 2019, 09:10
by rern
"Star" Image Issue
It's turned out to be serious and permanent, according to Last.fm API Anouncement.
Coverarts and images in Bio which use Last.fm as online source won't work anymore. I'm looking into getting them from somewhere else.
PostPosted: 26 May 2019, 10:04
by klassikmann
@rern
@janui
R101 wrote:Is there any way to update MPD in 0.5 the same way as the 0.4b addon did? The addon's changes to ffmpeg fixed the m3u8 streaming, which is the only reason I am still using 0.4b.
I second this question. My only reason to stay with 0.4b is the support of an actual mpd version resolving an issue in MPEG2-TS webradios containing MPEG1 Audio Layer 2 (mp2) streams.
klassikmann
PostPosted: 26 May 2019, 16:21
by rern
I've heard that janui and gearhead have been busy preparing next update/version which will have MPD installed as a standard package. Upgrading MPD would be straightforward by then.
The "star" image issue was resolved by switching to other sources. An update will be released soon.
Re: "Star" Image Issue
PostPosted: 26 May 2019, 17:28
by dynobot
never mind
PostPosted: 29 May 2019, 05:17
by rern
Update 20190529
- Fix "star" images (online fetched)
    - Playback coverarts - switch source to coverartarchive.org
    - Bio artists - switch source to fanart.tv
- Fix missing coverarts in album view
By the way, there's a delay issue with default RuneUI going on. RuneUIe users, please confirm that there's no such thing on your RuneUIe installed system, before and after this update.
PostPosted: 30 May 2019, 00:33
by dynobot
rern wrote:Connect to WiFi: (ESSID = WiFi name)
netctl-auto switch-to ESSID
By the way, did this happen after install Addons or RuneUI Enhancement?
This seems to have worked!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Still I'd like to be able to delete the test connection....
THANK YOU RERN!!!! :P :P :P :P :D :D :D :D :lol: :lol: :lol: :lol:
Now to cross my fingers and buckle my seat belt as I try to install the UI on the rest of my Rune setups
Thanks again rern
PostPosted: 30 May 2019, 00:55
by dynobot
Party over
Tried another ....no wifi, this command returned nothing
redis-cli get wlans | tr -d '\\"' | sed 's/,/\n/g' | grep ESSID
root@classicrunehavana(rw):~# redis-cli get wlans | tr -d '\\"' | sed 's/,/\n/g' | grep ESSID
root@classicrunehavana(rw):~# redis-cli get stored_profiles | tr -d '\\"[]' | sed 's/,/\n/g'
test
XXXXX<-----my saved network shows up...the one that worked before the reboot
It always turns my wifi off and can not be turned back on
Digging deeper.....rfkill list showed wlan0 was being soft blacked, I used rfkill unblock 0 to unblock it....after that wifi was back on BUT when I try to save the connection it will not save
Summary
Problem #1 - soft blocking wlan0
Problem #2 - not allowing new wifi connections to be saved
PostPosted: 30 May 2019, 02:28
by dynobot
More info
journalctl -xe
May 29 14:19:06 classicrunehavana dbus-daemon[257]: [system] Activating via systemd: service name='org.freedesk>
May 29 14:19:06 classicrunehavana dbus-daemon[257]: [system] Activation via systemd failed for unit 'dbus-org.f>
May 29 14:19:06 classicrunehavana sshd[3243]: pam_systemd(sshd:session): Failed to create session: Unit systemd>
May 29 14:19:12 classicrunehavana kernel: Voltage normalised (0x00000000)
May 29 14:23:09 classicrunehavana kernel: Under-voltage detected! (0x00050005)
May 29 14:23:13 classicrunehavana kernel: Voltage normalised (0x00000000)
May 29 14:23:15 classicrunehavana sudo[3552]: http : TTY=unknown ; PWD=/srv/http ; USER=root ; COMMAND=/srv>
May 29 14:23:15 classicrunehavana sudo[3552]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 29 14:23:17 classicrunehavana sudo[3552]: pam_unix(sudo:session): session closed for user root
May 29 14:23:17 classicrunehavana sudo[3579]: http : TTY=unknown ; PWD=/srv/http ; USER=root ; COMMAND=/usr>
May 29 14:23:17 classicrunehavana sudo[3579]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 29 14:23:17 classicrunehavana sudo[3579]: pam_unix(sudo:session): session closed for user root
May 29 14:23:27 classicrunehavana sudo[3619]: http : TTY=unknown ; PWD=/srv/http ; USER=root ; COMMAND=./se>
May 29 14:23:27 classicrunehavana sudo[3619]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 29 14:23:27 classicrunehavana systemd[1]: Reloading.
May 29 14:23:28 classicrunehavana systemd[1]: Starting Automatic wireless network connection using netctl profi>
-- Subject: Unit netctl-auto@wlan0.service has begun start-up
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/l ... temd-devel
-- Unit netctl-auto@wlan0.service has begun starting up.
May 29 14:23:28 classicrunehavana kernel: Under-voltage detected! (0x00050005)
May 29 14:23:28 classicrunehavana netctl-auto[3649]: The interface 'wlan0' is already up
May 29 14:23:28 classicrunehavana systemd[1]: netctl-auto@wlan0.service: Control process exited, code=exited st>
May 29 14:23:28 classicrunehavana systemd[1]: netctl-auto@wlan0.service: Failed with result 'exit-code'.
May 29 14:23:28 classicrunehavana systemd[1]: Failed to start Automatic wireless network connection using netct>
-- Subject: Unit netctl-auto@wlan0.service has failed
-- Unit netctl-auto@wlan0.service has failed.
-- The result is RESULT.
May 29 14:23:28 classicrunehavana sudo[3619]: pam_unix(sudo:session): session closed for user root
May 29 14:23:34 classicrunehavana kernel: Voltage normalised (0x00000000)
lines 1205-1239/1239 (END)
PostPosted: 30 May 2019, 02:44
by dynobot
fixed the under power issue now this
journalctl -xe
May 29 14:38:14 classicrunehavana devmon[682]: opticaldisc: []
May 29 14:38:14 classicrunehavana devmon[682]: numaudiotracks: []
May 29 14:38:14 classicrunehavana devmon[682]: blank: []
May 29 14:38:14 classicrunehavana devmon[682]: media: []
May 29 14:38:14 classicrunehavana devmon[682]: partition: [1]
May 29 14:38:14 classicrunehavana devmon[682]: ===========================================
May 29 14:38:14 classicrunehavana devmon[682]: changed: /org/freedesktop/UDisks/devices/mmcblk0p1
May 29 14:38:14 classicrunehavana devmon[682]: device: [/dev/mmcblk0p1]
May 29 14:38:14 classicrunehavana devmon[682]: systeminternal: [0]
May 29 14:38:14 classicrunehavana devmon[682]: usage: [filesystem]
May 29 14:38:14 classicrunehavana devmon[682]: type: [vfat]
May 29 14:38:14 classicrunehavana devmon[682]: label: []
May 29 14:38:14 classicrunehavana devmon[682]: ismounted: [1]
May 29 14:38:14 classicrunehavana devmon[682]: nopolicy: [0]
May 29 14:38:14 classicrunehavana devmon[682]: hasmedia: [1]
May 29 14:40:03 classicrunehavana systemd-timesyncd[237]: Synchronized to time server 45.76.244.202:123 (pool.n>
May 29 14:40:03 classicrunehavana systemd[1]: Reloading.
May 29 14:40:03 classicrunehavana hostapd[285]: wlan0: INTERFACE-ENABLED
May 29 14:40:03 classicrunehavana avahi-daemon[251]: Joining mDNS multicast group on interface wlan0.IPv4 with >
May 29 14:40:03 classicrunehavana hostapd[285]: Failed to set beacon parameters
May 29 14:40:03 classicrunehavana avahi-daemon[251]: New relevant interface wlan0.IPv4 for mDNS.
May 29 14:40:03 classicrunehavana avahi-daemon[251]: Registering new address record for 192.168.5.1 on wlan0.IP>
May 29 14:40:03 classicrunehavana kernel: brcmfmac: power management disabled
May 29 14:40:18 classicrunehavana sshd[1758]: Accepted password for root from 10.10.12.86 port 52856 ssh2
May 29 14:40:18 classicrunehavana sshd[1758]: pam_unix(sshd:session): session opened for user root by (uid=0)
May 29 14:40:18 classicrunehavana dbus-daemon[244]: [system] Activating via systemd: service name='org.freedesk>
May 29 14:40:18 classicrunehavana dbus-daemon[244]: [system] Activation via systemd failed for unit 'dbus-org.f>
May 29 14:40:18 classicrunehavana sshd[1758]: pam_systemd(sshd:session): Failed to create session: Unit systemd>
May 29 14:40:34 classicrunehavana systemd-udevd[209]: Process '/var/www/command/refresh_ao' failed with exit co>
