Page 42 of 65
Posted:
07 Feb 2019, 20:46
by AndyF
No noticeable delay here (Chrome on Android).
I think there's an issue on clearing the playlist at once. Playlist is empty after clicking on the most top "-". But entries are still shown until you switch between the tabs.
Andy
Posted:
07 Feb 2019, 20:58
by s.k.
Thanks for the feedback Andy.
I am on 0.5b 20180903-8.
I have a notable delay when the UI starts up and when it's switched back - from menu options.
In that delay period the Rune logo is displayed.
Onece the UI appears i can switch tabs faster than the previous version.
Playlist entrys appear faster also.
Is your version the same ?
Regards
Stavros
Sent from my ONEPLUS A5000 using Tapatalk
Posted:
08 Feb 2019, 05:49
by rern
AndyF wrote:...
To be fixed in next update.
s.k. wrote:...
The initial delay depends on how long it counts Library items. It can't be disabled at the moment but it will in next update.
Time it:
- Code: Select all
time /srv/http/enhancecount.sh
Posted:
08 Feb 2019, 06:30
by s.k.
I understand - it make sense.
time:
- Code: Select all
real 0m5.658s
user 0m0.888s
sys 0m0.206s
Thanks rern
Regards
Stavros
Posted:
08 Feb 2019, 16:57
by AndyF
Hi rern,
thanks for your reply - I´ve added function "clearPlaylist" from Update-branch an it works.
I´ve got an issue with "Debug"-Infos from Dev.-Menu. If you activate them, following output is thrown:
- Unbenannt.png (84.36 KiB) Viewed 1143 times
So I think, there´s something wrong
regards, Andy
Posted:
09 Feb 2019, 13:28
by rern
Hi Andy,
Many items in Development page should not applicable in RuneUI Enhancenent. The debug option is one of them. They will be hidden in next update.
Posted:
09 Feb 2019, 19:56
by AndyF
Hi rern,
in latest Update searching in library categories is broken. Results are visible for a very short time until library is visible again. Top and bottom bars are hidden after that.
Regards, Andy
Posted:
10 Feb 2019, 04:45
by rern
AndyF wrote:...
This is a big one. To be fixed soon.
Posted:
10 Feb 2019, 08:04
by AndyF
Hi rern,
thanks for your reply - in the mean time I did some workarround in enhance.js
$( '#db-search-close' ).click( function():
- disable getDB ( data );
- show hidden #db-back button
At the moment it works for me.
regards, Andy
P.S.: Hidden bars were some problems with Force-Immersive plugin for XPosed. Bars are working correctly. Sorry!
Update 20190210
Posted:
10 Feb 2019, 11:29
by rern
Update 20190210
Fix search bug
Fix delay on initial page loading with large Library
Improve text scrolling in scaled landscape mode on small screen
Add option to disable open Playback on Add+Play
