Page 41 of 65
Posted:
24 Jan 2019, 07:36
by Toube
So far so good.
I agree with Andy on having the back arrow on the left side at least when using a bigger screen it's easier to navigate. On small screen probably not so much difference.
Navigation now works and I can access the Library as with last version I couldn't.
Questions:
.cue files are opening playlists automatically I assume?
some folders are not opening.. just the logo loading showing.. with normal UI they work?
-Toube
Posted:
24 Jan 2019, 11:42
by R101
Please explain the "just change stations without doing it twice" thing.
If I select a station from the webradio list and use replace/play to add it to the playlist, info will not scroll.
If I go back to the webradio list and select the same station again using replace/play, the info on the playback page will scroll.
If I tilt the tablet 90 deg, the scrolling stops until I select the station again.
I think these problems started after the "tap once to add/play" feature. If I use tap once to switch stations a few times, the playlist becomes a mess, and the metadata info is replaced with the station name, so I do not use this feature.
Posted:
26 Jan 2019, 08:09
by AndyF
Hi R101,
I have modified my "dirty hack" - it should be less dirty now
- Code: Select all
function addReplace( mode, command, title ) {
if ( mode === 'wr' ) {
GUI.local = 1;
setTimeout( function() { GUI.local = 0 }, 500 );
if (command[command.length-1].indexOf( "play" ) !== -1 ) {
GUI.status.state='play';
setButton();
$.post( 'enhance.php', { mpc: command }, function() {
getPlaybackStatus();
new PNotify( {
title : title
, text : GUI.list.name
This simple code checks, if command-array contains "play". If there´s a play command, state would be set to 'play' and 'setButton' forces a button-refresh. Works on my setup.
regards, Andy
Posted:
26 Jan 2019, 12:58
by R101
Hi AndyF,
I have pasted your code in, (monkey see, monkey do - I have no idea how it works) but it does not affect the scrolling info problem I have.
Posted:
26 Jan 2019, 16:11
by AndyF
Hi R101,
my code don´t do anything with scrolling info - the only use is to refresh top playback buttons in library-tab on add/play a webradio-station. First "dirty hack" sometimes did a double refresh.
I looked into the code - scroll-mode don´t change if you resize your window or rotate your tablet. Sometimes it takes a long time until first infos are displayed. But at the moment I don´t know why.
Edit: It seems, Chrome on Android reloads the page if you rotate your tablet. So scrollmode changes on my system without problems.
regards, Andy
Posted:
28 Jan 2019, 17:09
by R101
Hi rern,
Info scrolling works for me on a local 7" Pi touchscreen, and on a laptop, but not on a 7" tablet.
Update 20190206
Posted:
06 Feb 2019, 13:12
by rern
Update 20190206
Fix Playback text scrolling on some devices
Fix text scrolling delay
Fix metadata refresh on add/replace + play
Fix search box display
Improve Playlist elapsed time display
Add tap swipe bar > drop down menu
Disable AAC/ALAC support for faster Library update(re-enable in MPD > FFmpeg setting)
Re: Update 20190206
Posted:
06 Feb 2019, 13:16
by Toube
rern wrote:Update 20190206
Hi Rern,
thanks for fast developing.
I will try it out.
Btw was there anything done for the folder problem.. or maybe I was the only one with the problem..
"some folders are not opening.. just the logo loading showing.. with normal UI they work?"
Toube
Posted:
07 Feb 2019, 19:16
by AndyF
Hi rern,
thanks for your update. It works fine so far.
One issue exists on Sources/NFS-mount: The "Advanced mount options" button has no effect. Original 0.5b-version works as expected.
EDIT: Problem is only on existing NFS-mounts. If you create a new mount, all work as expected. So no big problem.
Some GUI related things - Automatic swipe to playback-tab on add/replace-play should be optional. I don't like this on songs (because I'm a zapper), but for webradio it's cool. MP3s with some missing tags produce mixed metadata with previous song.
Regards, Andy
Posted:
07 Feb 2019, 19:17
by s.k.
There is an initial delay when you first open the RuneUIe20190206, from explorer and from the android app.
Is that normal ?
Regards
Stavros
(It isn’t a communication problem because the /dev page opens instantly)
