Page 30 of 65
Posted:
20 Nov 2018, 02:56
by poly6
rern wrote:@poly6
Your point is valid.
Like artist, album artist and composer - now genre is album based as well.
Thank you!
Posted:
21 Nov 2018, 11:48
by R101
Hi rern,
With UIe installed, I cannot see the Network > wlan0 > wifi stored profiles on 0.4 or 0.5.
It works OK if I uninstall the UIe.
Posted:
21 Nov 2018, 18:08
by hondagx35
Hie rern,
And also the possibility to connect to hidden SSIDs disappeared.
Posted:
21 Nov 2018, 18:42
by R101
That might have something to do with it - I have a hidden SSID.
Posted:
22 Nov 2018, 11:40
by rern
R101 wrote:With UIe installed, I cannot see the Network > wlan0 > wifi stored profiles on 0.4 or 0.5.
Fixed.
Posted:
24 Nov 2018, 21:57
by R101
Hi rern,
I notice that the playback page on different devices does not always sync.
For example, I had a radio station displayed on the playback page of a tablet, and used another device to select and play an album. The playback display on the tablet kept showing the radio information, including scrolling metadata, until the album playback reached track 6.
Posted:
24 Nov 2018, 23:13
by PierreG64
Hi rern,
I really like your new skin for runeaudio.
Despite all my attempts, installation, uninstallation, re-installation, the "library" button does not work on the taskbar. I can not access my files.
Everything works on the original version before installing UI Enhancement.
This on version 0.5b.
The other buttons work very well.
Is a bug known or am I alone?
if you have a solution to offer me. I thank you in advance.
Pierre
Posted:
25 Nov 2018, 18:57
by MikeC
PierreG64 wrote:Hi rern,
Pierre
Pierre,
Check to see if 'dev mode' is still on.
I have this issue when I forget to set dev mode back to off. I also find that I have to set "on/off" slider + "save settings" sequence 2 times.
Mike C
Posted:
26 Nov 2018, 19:50
by PierreG64
Pierre,
Mike C
Hi Mike C,
Thank you for your answer.
I tried with both methods, 'dev mode to off' and 'dev mode to on'.
I formatted the card and I installed a new system before each different test, the problem remains.
I can't access to my Library. The "Library" button does not work on the taskbar.
Pierre
Posted:
26 Nov 2018, 22:33
by R101
Pierre,
It works for me, so there must be something different about your setup. Is it just your files you cannot see, or do you not get any library items at all?
What other addons do you install? Have you expanded the partition? Does a source scan seem to work? Are all the library items ticked?
