Page 8 of 9
Re: 3x powersupply for rpi
PostPosted: 05 Dec 2017, 21:15
by dragos_nedelcu
I also left some space in the case for a singxer f1. Now i use gustard du u8, but i do consider the singxer and i am thinking of providing it clean 5v.Image
PostPosted: 05 Dec 2017, 21:18
by dragos_nedelcu
ricky007 wrote:Hello, do I have the onboard regulator removed? or is it enough to connect the power to PP9, PP7, PP5, PP8?
greeting
Ricky
I believe you should remove the regulator and the 2 inductors L1 and L2. I couldn't desolder so i ripped them with a plier. Not too clean, but it worked.
PostPosted: 11 Jan 2018, 12:54
by rastus
dragos_nedelcu wrote:The low freq are a bit booming. Hope the effect will go with burn in.
And, you will keep us updated of course, right?
PostPosted: 11 Jan 2018, 16:01
by dragos_nedelcu
Now it sounds sweet. I fotgot about the boom. It is gone with burn in.
PostPosted: 14 Jan 2018, 11:02
by rastus
Sweet is always good... and the boom has gone, good.... so all's well that ends well... good.
PostPosted: 28 Jan 2018, 10:36
by thanhvo31
Thí guy sell the board with pre config modules
Mezzanine Power board for Raspberry Pi.
http://www.ldovr.com/ProductDetails.asp ... ode=Mpower
PostPosted: 28 Jan 2018, 14:38
by dragos_nedelcu
It should be good, but: you still have the 2 noisy inductors and the regulator on the pi. If you remove them and use this, it might not work. And the pinout of pi3 doesn't have 1.8v.
PostPosted: 22 Feb 2018, 00:44
by gumof
is it possible to run rpi 3b+ without 5V -I don't need it..
PostPosted: 12 Sep 2018, 12:36
by nano35
Thanks for the instruction. A late comer here who modified a RPi3 model B with linear PS for 5V, 3.3V & 1.8V.
The audio improvement is enormous!
More dynamic, more power, more details, more engaging!
I am extremely happy with it.
Now someone mentioned about the C97 / C98 capacitors modding behind the USB unit.
I am eager to try it out and like to know in detail what to buy and how to install it.
I am a fresh DIYer and hope someone can help me out.
Thank you again.
My gear list:
RPi3 model B;
50VA transformer 2x9Vac secondary winding;
LT3045 regulator module to go down to 8Vdc;
then LT1963 regulators for 5V, 3.3V & 1.8V;
WD 500GB SSD;
EDUP wifi dongle;
PostPosted: 13 Sep 2018, 10:30
by linh0983
Hello!
This is a 3x power supply for my Pi3 after removing ic smps .
