DAB integration?
Posted: 31 Mar 2016, 14:05
I'm researching the best fit for a car audio project, and came across RPI/Digi+/headless Rune Audio as a possible candidate (main concern is optical out to feed into a Audison Prima AP8.9). From what I've read I can easily have a large music library and high bit-rate digital output with this setup, using a phone/tablet for UI
Has anyone been able to integrate DAB into a RPI, and get even basic support through the Rune Audio UI? If so, what DAB tuner did you use, dongle or board?
I'm a web developer and understand there are complexities integrating DAB with the UI - track names, signal etc would need to be updated using web sockets. However I only ever listen to one radio station! So I'd be perfectly happy setting the DAB tuner up and tuning through CLI then just having the basic ability to switch from music library to DAB and back again through Rune Audio UI.
Does anyone have any experience of this and can point me in the right direction?
Thanks, Dave
Thanks, Dave
