HiFiBerry Digi+ Works Best on RCA...!
Posted: 19 Aug 2015, 21:21
Hi All,
I bought the HifiBerry Digi+ board for my RP2 as a bit of an experiment. I tried the optical output into my DAC because I was cautious about the USB output from the Pi. Anyway, swapping between these two sources on my DAC showed no material difference.
It never occurred to me to test the RCA connection...
Today, I saw a video by technology journalist Hans Beekhuyzen on the HiFiBerry website, He tested an RPI2 with Digi+ board running Runeaudio. He outputs it to a Chord Hugo DAC (see https://youtu.be/DmeUxk14vCc or https://www.hifiberry.com/news/). He goes into some detail about the USB concerns, hence his configuration with the Digi+. He found the optical link wasn't nearly as good as the RCA output, which gave a noticeable difference in bass response compared with the other two options. Naturally, I couldn't wait to try it on my own system. He's right! It goes so much deeper now with lovely smooth, controlled bass.
Hans tested the Digi+ with the dedicated output transformer (the version I have) which benefits from galvanic isolation from the electrical output.
If you have a Digi+ board and haven't tried the RCA output, give it a try and see what you think. I'd be astonished if you didn't smile.
Trevor
Trevor
