Page 22 of 27
Re: Support for: 7″ Touchscreen Monitor for Raspberry Pi
PostPosted: 21 Apr 2016, 22:56
by wridley
wridley wrote:I downloaded and install the latest image -RuneAudio_rpi_0.3-beta_20141029_2GB and things were working fine. I then went and upgraded the kernal and firmware by running the command pacman -Sy --force raspberrypi-firmware-bootloader linux-raspberrypi
Upon reboot I have no audio output interface. How do I get it back. I was just using the analog output on the raspberry pi itself. I am using a RaspberryPi 2
Ok...... I remembered that I has a cheap Sainsmart HIFI Dac that came as a replacement for dead components so I decided to throw that on and see what happened. With enabling the hifiberry-dacplus I now have sound again. Only option is the hifiberry but it works!!
PostPosted: 22 Apr 2016, 12:32
by PiFi
Hi flipphos & Frank,
I too have been struggling to get xinput_calibrator to work. (I'm using the march 2016 image for Pi2 and Pi3 on a Pi2).
It wasn't installed, so first I did
pacman -S xinput_calibrator
I got xinput_calibrator to work through .xinitrc, but then you never get to see its output. xinput_calibrator does no configuration/calibration by itself, so that is an issue (it gives text output that you're supposed to paste in a config file by yourself).
In the end, what worked for me (and may be handy for others), is the following change to .xinitrc:
#!/bin/bash
export XDG_CACHE_HOME="/tmp/.cache" &
export DISPLAY=":0" &
# start the touchscreen calibration utility
# needed for some screens (Pollin 7" tft)
# for this to work you have to disable loading midori
#xinput_calibrator &
# turn on display power management, set to 15 minutes
xset -dpms 0 0 9000 &
# turn off screensaver
xset s off &
# start the window manager without titlebar and mouse
matchbox-window-manager -use_titlebar no -use_cursor no &
# install multimedia keyboard shortcuts
xbindkeys &
# start midori in privat mode with fullscreen display
#midori -p -e Fullscreen http://localhost
xinput_calibrator > /var/log/xinput_calib.log
Note there is no & at the end of the xinput_calibrator line, it does not work for me with & added.
The nice thing about this trick is that then you can go to /var/log/xinput_calib.log to see what it outputted.
In my case, the following:
[root@runeaudio log]# cat xinput_calib.log
        Setting calibration data: 0, 4095, 0, 4095
Calibrating EVDEV driver for "Microchip Technology Inc. AR1100 HID-MOUSE" id=6
        current calibration values (from XInput): min_x=0, max_x=4095 and min_y=0, max_y=4095
Doing dynamic recalibration:
        Setting calibration data: 85, 3992, 19, 4097
        --> Making the calibration permanent <--
  copy the snippet below into '/etc/X11/xorg.conf.d/99-calibration.conf' (/usr/share/X11/xorg.conf.d/ in some distro's)
Section "InputClass"
        Identifier      "calibration"
        MatchProduct    "Microchip Technology Inc. AR1100 HID-MOUSE"
        Option  "Calibration"   "85 3992 19 4097"
        Option  "SwapAxes"      "0"
EndSection
So then I added that config to /etc/X11/xorg.conf.d/99-calibration.conf (had to create that file), re-edited .xinitrc to disable xinput_calibrator again, and enable midori, and then reboot.
That did the trick for me! I hope this is helpful to others!
PiFi
PostPosted: 22 Apr 2016, 13:14
by hondagx35
Hi PiFi,
thank you for the tip.
This will be changed with the next image.
I checked this again and it is installed on the latest image.
PostPosted: 22 Apr 2016, 17:59
by PiFi
you're very welcome. Thank you (and all other contributors) for creating such a great system! I'm loving it.
From your comment, it would seem that I'm not using the latest image then (I'm using RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB.img). Can you point me to where I can find the latest?
Thanks!
PiFi
PostPosted: 08 May 2016, 12:09
by piccy
Am using the touch display and apart from a wish to make control icons larger it works ok , it also seems to be more responsive when used with a pi3 which i have just fitted in place of pi2 ,
my question is are there any issues with screen burn on lcd monitors ? , if there is can a screensaver be implemented or the screen blanked when not been touched for say 5 mins ?
thanks
PostPosted: 08 May 2016, 13:14
by morias
piccy wrote:Am using the touch display and apart from a wish to make control icons larger it works ok , it also seems to be more responsive when used with a pi3 which i have just fitted in place of pi2 ,
thanks
Look for the discussion about xset dpms 0 0 300 & a few pages back in this thread for instructions. It will blank the screen after 5 minutes. Touching it again wakes it up.
Sent from my iPad using Tapatalk
PostPosted: 06 Jun 2016, 08:44
by darknix
I am new to this platform, and I'm building a player system, with the following:
Hardware:
Raspberry Pi 2 model B
IQaudio Pi-Dac+
Waveshare 5 inch HDMI LCD (B) touchscreen with USB
Software:
I managed to make the system play songs with the sound card, showing the control panel on the 5 inches screen. But I'm having trouble making the touch work.
I have try to install and run "DISPLAY=:0 xinput_calibrator" both remotely and locally on the pi 2 itself, and results in
[root@runeaudio ~]# DISPLAY=:0 xinput_calibrator
Error: No calibratable devices found.
Then I have ran "lsusb" and result:
[root@runeaudio ~]# lsusb
Bus 001 Device 006: ID 0781:5575 SanDisk Corp.
Bus 001 Device 004: ID 0eef:0005 D-WAV Scientific Co., Ltd
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Then I have tested the touchscreen with the Waveshare Raspbian image and the touch works.
I have be testing the system for 2 days and I couldn't make the touchscreen to work.
Can anyone point me to the right direction on solving this issue?
Thank you.
PostPosted: 06 Jun 2016, 09:43
by hondagx35
Hi darknix,
welcome to RuneAudio.
Please try this.
PostPosted: 07 Jun 2016, 02:10
by darknix
Frank,
Thank you very much for the reply.
I am working on it.
Edit:
I have finished the steps in https://wiki.archlinux.org/index.php/Multitouch_displays
Unfortunately the touch is still does not work after reboot.
PostPosted: 12 Jun 2016, 02:09
by raid3868
I have raspberry pi 3 + DAC + 7" LCD touchscreen and think work very well, Thank you to renuaudio hardworking to
bring this feature and is great.
Got some issue below.
1). On local lcd on top of the left hand side is display clock instead of Renuaudio logo, and the clock display is different from the system time. How can i change to Renuaudio logo or get to display the actual system time?
2). Possible to set the brightness of lcd on startup?
Hope someone can help.
Thank you very much.
