Getting a DAC+ setup
Postby audio007 » 26 Sep 2016, 18:09
Sorry that this covers old ground for many of you but I need an injection of knowledge!
My problem is that Rune is not seeing my HiBerry DAC +. (It was seen when I was running Volumio)
I have a PI2, 0.4 Rune, Win10 with PuTTY so I can SSH to the SD card insitu.
I understand that config.txt needs the DAC+ line to have its remark '#' removed and then rebooted.
I have done this but it is still not showing in Rune Settings.
I am sure it is something obvious but since this is all fairly new to me it isn't obvious!
PS Tried to add a debug file but the forum would not accept it ??
audio007
Re: Getting a DAC+ setup
Postby popov » 27 Sep 2016, 06:34
audio007 wrote:Sorry that this covers old ground for many of you but I need an injection of knowledge!
Envoyé de mon iPhone en utilisant Tapatalk
popov
Postby popov » 27 Sep 2016, 06:40
Sory an issue in train ... message live empty..
Do you have a look to setings ? I2s have to be activated. After you normaly could see dac in mpd menus.
If not working connect in ssh have a look to lsmod. You should see module for hi Berry, load and link to snd. If not ... you are not came from config.txt or card
popov
Postby hondagx35 » 27 Sep 2016, 16:29
Hi audio007,
please post your debug info.
Postby audio007 » 27 Sep 2016, 16:35
hondagx35 wrote:Hi audio007,
I would if I could Frank but it won't accept my file Debug.txt, it says the extension txt is not allowed.
audio007
Postby audio007 » 27 Sep 2016, 16:43
It also rejected a pdf version ??
audio007
Postby hondagx35 » 27 Sep 2016, 16:45
Hi audio007,
Collecting debug info
HOW TO COLLECT AND POST DEBUG INFO
  1. In the RuneUI, go to MENU > Debug;
  2. Refresh the page a couple of times, waiting some seconds between every refresh
  3. Click the "COPY DATA TO CLIPBOARD" button;
  4. Go to http://pastebin.com and paste the debug output in the "New Paste" textarea. Leave the default options (Syntax Highlighting: None, Paste Expiration: Never, Paste Exposure: Public), give a name to il (e.g. RuneAudio debug info) and submit.
  5. Copy the url of the submitted Pastebin (e.g. http://pastebin.com/dL1k9irT) and include it in your post here in the forum.
Please also post your config.txt.
Postby audio007 » 27 Sep 2016, 16:51
Thanks, I was trying the Upload Attachment process.
http://pastebin.com/Ky3pEQvN
audio007
Postby hondagx35 » 27 Sep 2016, 17:11
Hi audio007,
Code: Select all
[    6.376763] snd-rpi-hifiberry-dacplus sound: ASoC: CPU DAI (null) not registered
[    6.376790] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
[    6.380803] snd-rpi-hifiberry-dacplus sound: ASoC: CODEC DAI pcm512x-hifi not registered
[    6.380828] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
[    6.560537] pcm512x 1-004d: Failed to reset device: -5
[    6.560665] pcm512x: probe of 1-004d failed with error -5
Is this we only change you made? Please check this again.
Code: Select all
#dtparam=i2c_arm=on
#dtparam=i2c_vc=on
#dtparam=i2s=on
#dtparam=spi=on
#dtparam=act_led_trigger=mmc
#dtdebug=on
#dtparam=uart1=off
#dtoverlay=pi3-disable-bt-overlay
# Uncomment one of these lines to enable an audio interface
#dtoverlay=hifiberry-dac
dtoverlay=hifiberry-dacplus
#dtoverlay=hifiberry-digi
#dtoverlay=hifiberry-amp
#dtoverlay=iqaudio-dac
#dtoverlay=iqaudio-dacplus
Postby audio007 » 27 Sep 2016, 17:27
I have just gone through the file with nano and found only one other line without '#'
It was an LCD line, so I added one
I am rebooting and will post the new debug txt shortly
audio007
